Originally Posted by visioneer Nooooooo!! After the inevitable hours (days..weeks  ) of research, I'd decided that the CX105 was probably the best option for my budget. It's available at Jessops for £369, less £60 sony cashback, and also less £20 Jessops 'birthday20' voucher code, meaning its available for £289.
Now, my use is going to be similar to the OP and I'd sort of accepted that the indoor stuff might not be brilliant, but when the 520 (£900) and tm300 (£700) are so much more expensive I had concluded that the low light (I'm beginning to despise that phrase  ) performance of the better models was unlikely to be twice or three times as good. Please correct me if I am wrong. |
You are Probably right but you may not need up to twice the low light performance to have a noticeable improvement
I do have the XR200V for test use and I find its indoor low light very disheartening. Certainly on auto it is dismal. On Manual , it is better, at the expense of noise
It has a small 1/5" sensor which the Bionx and exmor technology could not (IMHO) rescue
My advice to avoid it is in reference to someone who has experienced similar with the SD10.. The Sony will be no better
My brother bought the Canon HF200 and I had a go of that indoors at night and it had noise issues too and that is in the £450-£500 bracket similar to the Panasonic SD200.
The SD 200 is better but that is also a matter of degree
I had low light noise issues (albeit I didn't consider them to be a problem) when using my old Panasonic NVGS3 (old, v.old MiniDV model that served faithfully until last year) so understand your comments entirely regarding the DV format. I've just spent a good while transferring footage off tape through a HDD based Sony DVD Recorder and I've been impressed with the footage off the tapes that I have taken over the years, even though it is 'just' SD
Compared to the more pocket friendly camcorders of today, MiniDV Low light isn't bad at all.
So, re 'low light' how do they compare - £300 - £500 - £700 - £900?? At the end of the day, I'll be using mine to record family events etc and I'm not convinced that when looking back at it in 5 years, 10 years, 20 years time that I am going to be too concerned that there is 'noise' on it.
The increase in price isnt only related to low light performance and things like gps, face recognition, shutter smile make the XR200V costlier than the 106 but Im pretty sure the Video performance is similar
Provision of viewfinder, mic-in, headphone-in Manual focus , ect and TBH better video, dual recording media and better stills ability do bump the price up
Im not advocating spending over the odds but if mixed results lead to using the camcorder less, Spending a bit more may be a good idea
These are usually one off purchases which means the pain will go, eventually
Im sure all these kit will have their friends and folk learn to live with their limitations
.. and some have described them as " memory makers" , not Pro video equipment
but lacklustre performance might induce a degree of limited interest in their use IHO
