Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 8:30pm and include delivery.
Panasonic PT AX200 - Owners reviews, settings, screenshots, problems etc Sami Projectors 555 Today 1:35 PM
Wanted : all sorts of box sets echo Movie and Music Classified Adverts 335 Today 1:29 PM
Optimum Monitor Settings h3LLb0y Computer Monitors 6 Yesterday 12:31 AM
My B&W XT set up magicvinny Members' Home Cinema Gallery 32 18-11-2009 2:21 AM
Help set up my dvd recorder lornat DVD and Blu-ray Recorders, Recording and Media 13 16-11-2009 1:18 PM
Old 06-11-2009, 6:00 PM   #1 (permalink)
Which Rendering Settings For Vegas?
I have been getting used to my new Canon HF200 for a few weeks now and I have been fiddling about with Sony Vegas also.
I am not totally up to speed with all the settings in Vegas in terms of how to set up my project and then which settings to use for final rendering of the project.
Do I have to match the settings of the HF200 in terms of, e.g. 50p, 720-30p, PAL DV Widescreen, etc. to set up the project?
Do I have to match the render to the camera output? E.g. if I shoot in cine mode at 25p should I match this some how in the project??
Is there much of a difference between an AVI render and a WMV render?
So far I have noticed that AVI looks better quality and the WMV shows some horizontal 'interference' on footage when viewed back, although is a smaller file.
Really confused, is there a basic guide somewhere to help me understand?
Stu
stuu3270 is offline   Reply With Quote
Old 06-11-2009, 8:47 PM   #2 (permalink)
Thanks: Gave 425, Got 2,078
Re: Which Rendering Settings For Vegas?
Originally Posted by stuu3270 View Post
Yes otherwise there will be a lot of rerendering once you do an edit , even one as simple as trimming
No you can render however you wish, as long as it is available in
Vegas, even if that happens to be the camcorders own setting, bearing in mind the software own rendering codec may not be identical to the camcorders
AVI is not a file format but a wrapper format which can be " host" to DV AVI or any of divx, xvid, mjpeg or mpeg4 ,
These codecs are more compressed than DV AVI
Saying that some of the mpeg4 " avi" files may be less compressed than the wmv.. which can be good depending on how compressed they are
There are compression artifacts which may be what you are seeing but if it is due to deinterlaced footage
There is WMV-HD.
There are several , but it would take more than a thread post to cover even the basics
Specific queries about what you are trying to do would be easier as the answers would be bite sized.
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 07-11-2009, 11:43 AM   #3 (permalink)
Bruin's Avatar
Thanks: Gave 2, Got 2
Have you found the built-in tutorials yet? I find them very useful and this page
Sony Creative Software - Vegas Pro Training Series, hosted by Les Stroud
Has some good videos as well
Bruin is offline   Reply With Quote
Old 07-11-2009, 5:30 PM   #4 (permalink)
Thanks Senu,
I think I have made some progress. I tried rendering a single shot of the project I have as WMV. I then changed the deinterlace method for the project. 1 = none, 2 = blend 3 = interpolate.
With each render, any fast moving things, e.g. dog's tail wagging, became more natural looking. The first showed horizontal lines across the moving part, second slightly better and the third looked normal.
When I rendered I went for default template. Will I see any difference to worry about if I choose another, e.g. 8Mbps HD 1080-30 video? What do they all mean?
Stu
Old 07-11-2009, 8:35 PM   #5 (permalink)
Thanks Senu,
Stu
All the output settings will be one optimised for
PC
HDTV playback
And will try to give you a good compromise between file size and quality
The interlace can be turned on in the media player , but a lot of your trial and error methods are not a bad way to find what works best for you
The linked tutorials by Bruin are also helpful for other things
S3Stuff
rendering, settings, vegas
[IMG] code is Off
