Sony HDR-TG7VE - first impressions
Old 05-11-2009, 12:28 PM   #1
Dancook's Avatar
10,743, Level: 24
Points: 10,743, Level: 24 Points: 10,743, Level: 24 Points: 10,743, Level: 24
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 1,400, Got 798
So yesterday at 4pm I ordered this from Amazon and had it on my desk at 9am this morning. For £550, I could have probably saved a little by shopping around, but with Amazon's service being as reliable as it is, I am happy to pay a little more.
All I've done is to take a few quick videos around the office and upload them to my work pc for playback. I am not skilled in camera work, I'm a bit of a newb!
The greatest thing I love is that I can pop the camcorder in my pocket. Also it's ready to go within seconds of opening the screen. It's a lot more convenient that taking your camcorder out of a bag and setting it up ready to record a moment which has ended already!
The battery limit is 120mins. I tried it the 9mb/s and 16mb/s HD video, the 16gb inbuilt memory could store approximately 220mins and 120mins respectively.
Whilst recording it was interesting to note square boxes forming around a colleagues face, I wasn't really aware of this feature. But once I imported the video, a photo of his face appeared in the software, clicking on it showed me the videos he was in!
Playing back the HD video on my work pc, the quality of the 16mb/s recording was marginally better, but the jerky motion was worse. That could be down to my camera skills or the pc specification. I will see what can be done about that. If I can reduce the jerkyness or work out why it is, then I would probably use the 16mb/s option.
I tested the still camera function, it seemed pretty good, but not as good as the Sony dedicated compact we have.
I'm happy with my purchase and I'm looking forward to having a proper play!
Old 05-11-2009, 2:12 PM   #2
5,045, Level: 16
Points: 5,045, Level: 16 Points: 5,045, Level: 16 Points: 5,045, Level: 16
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 72, Got 21
Re: Sony HDR-TG7VE - first impressions
Thanks for the review on this model. I've been looking at a review of it this morning. It's the current PCPro 'A' list camcorder.
Let me know if the 'jerkiness' issue gets resolved.
Old 05-11-2009, 2:24 PM   #3
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
I'm not so sure it's an 'issue' as such
do not shudder at the judder
So is 24 frames per second OK for actually capturing the motion on set? Actually it isn't ideal, it really is low horsepower. It is not taxed by talking heads and wide shots with not much movement. but when the subject starts to move the cinematographer has to be very aware of the limits the subject can move between frames. If the subject moves too much then they will appear to judder.
Old 05-11-2009, 2:30 PM   #4
5,045, Level: 16
Activity: 2.3%
Originally Posted by Dancook View Post
I can't get my head around all that!!
Old 05-11-2009, 2:59 PM   #5
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
I'm not 100% sure..but if you're panning quickly, you should do it fast enough that it blurs.. otherwise you'll see a judder.
and maybe If you're concentrating on a moving subject, move with them so that the background might judder...but it won't be noticeable on the subject.
I think it's down to my inexperience and not a problem with this actual camcorder.
there could be techniques and settings to create improvement, but it won't be just this camera.
Old 05-11-2009, 3:03 PM   #6
5,045, Level: 16
Activity: 2.3%
Ok, thanks for that. On a separate note, when you transfer the files to your PC what exact file type does the camcorder use? I've been looking at a canon hf200 and that uses .mts files which are fine for my PS3 to play - need to know if this camcorder will work ok too.
Old 05-11-2009, 3:09 PM   #7
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
Three files are created for each video capture, modd, moff and m2ts.
Old 05-11-2009, 3:11 PM   #8
5,045, Level: 16
Activity: 2.3%
I recognise the m2ts file - if you play that does that contain the video and audio together?
Old 05-11-2009, 3:16 PM   #9
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
Yes it contains both video and audio stream, the PMB software creates the other two files when it analyses the video
visioneer (05-11-2009)
Old 05-11-2009, 6:29 PM   #10
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
Just tried the camera at home, no judder! Home PC is substantially better than work pc.
Old 05-11-2009, 6:41 PM   #11
5,045, Level: 16
Activity: 2.3%
I notice that this camera records 1080i rather than 1080p. In terms of picture quality etc does this make a difference does anybody know? I read on tomshardware that there may be issues with making bluray discs from this????
Old 05-11-2009, 8:12 PM   #12
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Not really
No there wont
visioneer (06-11-2009)
Old 06-11-2009, 12:13 AM   #13
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
Youtube isn't the best method to show off the quality of a camera, but i think it still looks pretty good
I uploaded the raw file that the camcorder gave me, 300mb in size and youtube gave me this.. check out HQ
YouTube - Guildford Fireworks 2009 Part 1 of 3
Old 06-11-2009, 6:48 AM   #14
47,154, Level: 53
Activity: 2.7%
Pretty good
Old 06-11-2009, 9:51 AM   #15
5,045, Level: 16
Activity: 2.3%
Footage looks good - I've never filmed fireworks before but I imagine it's a tricky thing for any camera to deal with regarding focus and light etc.
Old 06-11-2009, 10:14 AM   #16
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
I put it on the 'fireworks' setting easy as pie.
Old 06-11-2009, 11:09 AM   #17
8,266, Level: 21
Points: 8,266, Level: 21 Points: 8,266, Level: 21 Points: 8,266, Level: 21
Activity: 22.0%
Activity: 22.0% Activity: 22.0% Activity: 22.0%
Thanks: Gave 16, Got 189
Properly used Progressive can have a better look than interlaced all tv material is in P mode exept possibly the rubish news footage we often get, but P mode realy needs tripod use and only controled panning.
Old 08-11-2009, 9:28 PM   #18
Dancook's Avatar
10,743, Level: 24
Activity: 6.8%
YouTube - Ducks and Chicken - Sony HDR-TG7VE
Another vid uploaded, check it out in HD. obviously youtube have done thier conversions.. but it doesn't look bad!
Old 13-11-2009, 10:19 AM   #19
sneeks's Avatar
11,083, Level: 25
Points: 11,083, Level: 25 Points: 11,083, Level: 25 Points: 11,083, Level: 25
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 221, Got 311
I bought the previous model of this, TG3E, two weeks ago from Currys for £275 and am delighted with it. From what I've read both cameras are nearly identical but for the new menus, in-built memory and GPS function?
Old 13-11-2009, 10:27 AM   #20
5,045, Level: 16
Activity: 2.3%
@Dancook - last clip, quality wise, seems A1 to me. I would be more than happy with that quality for what I need.
@Dancook and sneeks - do these camcorders have a tripod screw thread on the bottom? How have you both found these for indoor filming? I will use mine for filming the kids, holidays, birthday parties etc so indoors likely to be an issue fairly often.
Thanks in advance.
Old 13-11-2009, 11:33 AM   #21
sneeks's Avatar
11,083, Level: 25
Activity: 4.9%
Yes the camera can be tripod mounted with the usual screw on the underside. Indoor filming has worked OK for me if the room is well lit. If not then I try to avoid using the zoom as this can cause focus problems. I think I will ideally need to buy the wide angle attachment though for indoors, as standard I feel it is a bit narrow when in a confined area.
Old 13-11-2009, 11:37 AM   #22
5,045, Level: 16
Activity: 2.3%
Sounds good to me. I also looked at the Sony HDR-CX105 which can be bought from Jessops at £369 less £60 Sony cashback, giving a net price of £309. Wondered whether you might have looked at that model at all? I'm torn between the TG7/TG3, Canon HF200/Pany SD200 and this Sony HDR-CX105.
Old 13-11-2009, 11:56 AM   #23
sneeks's Avatar
11,083, Level: 25
Activity: 4.9%
All the positive user reviews I have read convinced me that the TG3 was the right camera for me and also the form factor of it was ideal for what I wanted. It is a very pocket friendly camera. I had also looked at a very similar list of cameras but the cheap price I found my TG3 for in Currys was ultimately why I finally bought it. It's a great camera for the money.
I see John Lewis also sell the Sony HDR-CX105 for £369 complete with a 2 year warranty.
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 12:30pm. Prices include delivery.
[IMG] code is Off
