| Re: Camcorder advice please
You might like to consider the Panasonic SDR S26. It utilises a CCD sensor, and Optical Image Stabiliser (OIS) both of which are important featueres for taking video where rapid movement is likely.It is also compact.
You can find some reviews from the advert banner at the top of this page.
Canon do similar models - the FS100 for example - although that doesn't have an optical image stabiliser.
Generally speaking, optical image stabilisers (OIS) are much more useful than electronic image stabilisers (EIS).
