Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 1:30am and include delivery.
Sony TRV740E Hi8 Tape download to PC ppanyam Camcorders and Video Editing 9 04-11-2009 5:52 AM
Old 01-11-2009, 10:30 PM   #1 (permalink)
Smile Archiving DV Tapes (for a novice)
I have a Sony DCR-HC47 and now want to archive the DV tapes I have accumulated. Can anyone suggest the best and most straight forward way to do this so that:
1-The quality is not affected and
2-Easy to playback on TV
Is there any particular software that I should use?
Better to store on DVD or hard drive
I'm not particular great with technical stuff so the easier the better, but still want to keep the quality.
mudpie is offline   Reply With Quote
Old 01-11-2009, 10:56 PM   #2 (permalink)
Thanks: Gave 425, Got 2,078
Re: Archiving DV Tapes (for a novice)
DV tapes are really the best archive actually
The Advantage of using a HDD is easier randon access
There is no "straightforward" way short of capturing to Your Pc and converting to mpeg2.
Mpeg2 is DVD video quality but smaller filesize than DV AVI which is how they are on th tae
This means using a video file converter
You can then store these on a hdd and make Data DVD copies as additional backup given that neither HDD nor DVD media are infalible
For TV playback you can create DVD videos from the atchived files ( if you dont want to watch the tapes)
or Get a Media Player (I use a relativey afordable WDTV £70) which can play any supported file on a USB device to TV
Unles you have to I would advise you keep your tapes well and dont dispose of the camcorder
It is the easiest playback with best quality combo, for now
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 02-11-2009, 9:53 AM   #3 (permalink)
Thanks.
I'll definitely keep the tapes etc.
Is there a particular video file converter that you would recommend?
Old 02-11-2009, 9:57 AM   #4 (permalink)
I use Canopus Procoder ( there is an express version) . For Dv to mpeg2, Ver2 is fine ( they are now on ver 4). The express version is better VFM for a simple need. like yours
There are many converters out there though but I find Procoder fast and good quality. Im sure others may be but I guess Im a creature of habit. If I find one that works I dont look any further...
PM Me for more details if you wish
S3Stuff
archiving, digital video essentials, novice, tapes
[IMG] code is Off
