Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 4:30pm and include delivery.
Crazy Cameras Von Ryan Digital Photography General Chat 434 Today 1:59 PM
For Sale : Canon 75-300mm III Zoom Lens (and EOS 300 Film Camera) Goody Digital Camera and Camcorder Classifieds 5 01-11-2009 7:08 PM
3.5mm/biggest screen/best camera gwladys Mobile Phones and PDAs 0 01-11-2009 5:02 PM
safety camera alert not working tomele Satellite Navigation (Sat Nav) 0 31-10-2009 12:27 PM
Old 01-11-2009, 9:18 PM   #1 (permalink)
Capturing VHS-C from camera or VHS player?
Hi.
I have some compact VHS tapes that I am trying to capture on my pc's hard disk.
I am using the analog-->digital facility on a Sony DCR-TRV30E camera to convert from composite video to DV.
I have two options for playing the source material:
(a) Play the tapes in the 18-year old camera that was originally used to shoot the material.
(b) Play the tapes in a VHS-C adaptor inserted into a JVC DR-MX10 combination VCR/HDD/DVD player
The picture is better using (b) but the audio gain using (a) is 3dB higher.
Anyone know how I can increase the audio gain on the DR-MX10 output? Or any better ideas?
(Note: I tried transferring from VHS tape to DVD using the MX10's dub facility but the audio output level on the resulting VOB isn't any higher than the output from the MX10's red and white audio connectors. )
Pandora is offline   Reply With Quote
Old 02-11-2009, 8:37 AM   #2 (permalink)
Thanks: Gave 5, Got 113
Re: Capturing VHS-C from camera or VHS player?
Aside from the volume issue the best bet is stick it on dvd first .Then its easy to get it on the pc for editing if requred
jaymac is offline   Reply With Quote
Old 02-11-2009, 9:10 AM   #3 (permalink)
Thanks: Gave 6, Got 109
The dvd recorder way would be easiest again if you have one, the tapes could be copied via the cam or a vhs player but you need a dvd player or can borrow one.
chrishull3 is offline   Reply With Quote
Old 02-11-2009, 4:29 PM   #4 (permalink)
Thanks: Gave 425, Got 2,078
..recorder
A settop one
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is online now   Reply With Quote
Old 02-11-2009, 8:17 PM   #5 (permalink)
Thanks: Gave 10, Got 166
The OP has a DVD recorder (DR-MX10 is a VHS/DVD combo).
This contradicts your experience, but I always thought tracking, head switching etc. meant tapes were best played in the device that recorded them.
Check the audio features of the original camcorder and the MX10. Were the tapes recorded in edge-track (linear) mono, or Hi-Fi stereo? Are there any recording-level gain controls on the MX10 etc. What about the level at its scart output.
Edit. Just noticed OP specified DR-MX10 is the VHS/DVD/HDD combo - thought I recognised the model number.
I'd be tempted to record my tape - once - to the HDD in the highest quality it allows, then transfer sections to DVDRW and adjust the audio gain in software on the PC.
28" TV; Philips VL1400 AV Tx, VR530, LDP600 (CD-Video/Laserdisc), Matchline amp and speakers, Prestigo SRU8015 RC; Humax PVR9200T; Tevion PVR801; Thomson Scenium DTH7000e; Phoenix Apollo FTA; PC/capture card~ watch/record alternate source, create DVDs from the Humax and play audio through the amp.
nvingo is offline   Reply With Quote
Old 02-11-2009, 11:30 PM   #6 (permalink)
Thanks for your replies, chaps.
Whilst I can do a VHS-->HDD-->DVD transfer on the DR-MX10, the resulting file is in mpeg 2 format.
MPEG is a delivery format and was not designed for editing. If the file is an mpeg, I would need to convert to AVI first to use it in my editing software (Premiere Pro).
Not sure how to do this.
Old 03-11-2009, 5:41 AM   #7 (permalink)
Most editors will edit Mpeg and have the benefit that it only recodes not reccodes any section that has been edited .Premiere pro will edit mpeg it prefers Avi but it will edit Mpeg
. Converting to avi and reconverting to get back on dvd can affect quality
Old 03-11-2009, 5:45 AM   #8 (permalink)
Mpeg2 can be edited , reasonably painlessly now.
Adobe Premiere Pro will edit it ( even if it does so by converting to AVI in te background)
If you must convert to AVI you may be best of using an intermediate codec like Cineforms ( Which Vegas Uses) .
The Advent of HDV (whichis natively Mpeg2 ) meant that many editors are able to edit mpeg2 fairly well without generational PQ loss from
rerendering
If you must do as you wish you can input mpeg2 into Preimere ro, output DV AVI then edit that but it seems needlessly long winded to me and a quality leecher.
PS: was posting same time as Jaymac..
S3Stuff
Old 03-11-2009, 5:48 AM   #9 (permalink)
The early bird Senu
Old 03-11-2009, 5:50 AM   #10 (permalink)
Originally Posted by jaymac View Post
The early bird Senu
Going back to bed now..for 10 mins!
S3Stuff
Old 03-11-2009, 8:33 AM   #11 (permalink)
Originally Posted by senu View Post
..recorder
A settop one
i did say dvd recorder but left out rcorder part nest sentence i think he knows what i meant
Old 03-11-2009, 9:35 AM   #12 (permalink)
rerendering
Unfortunately, I am using Premiere Pro 1.5, which received wisdom seems to suggest is not great at handling mpg files on the timeline (for example)
For a novice like me, converting from mpeg to avi seems a bit more art than science.
I'll experiment a bit more...
Old 03-11-2009, 9:44 AM   #13 (permalink)
Thanks: Gave 0, Got 35
Converting from mpeg2 back to DV AVI is simply just introducing one further stage of quality loss.
Better to convert straight to DV, using the Sony camera pass through, and then increase the audio gain by 3dB in your editor. Then export your final edited output in whatever form you choose. Minimises quality loss that way.
(Plus the fact that you are no longer restricted to 'real time' MPEG2 conversion, if that is your final destination)
rogs is offline   Reply With Quote
Old 03-11-2009, 9:45 AM   #14 (permalink)
I think that what you say is true. But I think that the age of the camera means that the playback quality has deteriorated. There is too much "picture noise" - dirty recording head may be?
Good points. The microphone on the camera is Hi-Fi stereo. You can program for this on the MX10. There is no audio gain control on the MX10 as far as I can see (I've read the manual cover-to-cover). Would the scart audio output be better than the red and white bnc audio output connection? I assumed that it would be identical.
That's probably what I'll do to archive the material. Ten years ago the analog output from the camera would have been better but it's too old now I think.
Old 03-11-2009, 9:50 AM   #15 (permalink)
With my limited experience, I have to agree that this gives the optimum results.
Given the capabilities of the DX10. I'll probably archive all the VHS-C tapes onto DVD using that machine so that I have a "modern" backup.
However, for selected clips that I want to incorporate into Premiere Pro projects, I'll capture them from the VHS-C tapes via the Sony DV camcorder.
camera, capturing, player, vhs, vhsc
[IMG] code is Off
