Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Samsung SMX-C10
Panasonic HDC-SD200
 More...Prices updated November 25th at 3:30am and include delivery.
Pro Evolution Soccer 2010: Play and Help Hillskill Xbox 360 Games 110 Yesterday 11:17 AM
Wheel stand pro for forza 3 Ayman Forza Xbox 360 96 23-11-2009 9:11 PM
Pro evo 2010 Indecisive Jay PC Games 417 22-11-2009 9:37 PM
For Sale : Lexar 8gb pro duo £15 plus 3 games JonnyConcrete PSP Classified Adverts 11 30-10-2009 9:06 PM
Old 30-10-2009, 9:31 PM   #1 (permalink)
Thanks: Gave 5, Got 0
HELP PLEASE... with Adobe Premiere Pro CS3?
Hi there
I've just edited a showreel on Adobe Premiere Pro CS3
When I export my film to burn to DVD via Adobe Encore...
I play my DVD on my TV and it does not fill up the TV screen, it is just a square box in the middle about a quarter of the size of the screen?
It won't let me change the frame size in the settings but it is automatically set at 720X576? to play on TV should it not be more like 1920X1200 or something?
It's very frustrating as I have been working on this a very long time and I need to get it on DVD "FULL SIZE" to play on a full size 32inch HD TV?
Please any help atall would be much appreciated
Best wishes
Silver Sky is offline   Reply With Quote
Old 30-10-2009, 10:06 PM   #2 (permalink)
Thanks: Gave 138, Got 36
Re: HELP PLEASE... with Adobe Premiere Pro CS3?
what was the source material shot in ? (Format and Aspect) ?
It sounds like the project has been set based on the material. One thing you could try, is to create a new project - then cut/paste the entire timeline into the new project. Render and try again.
I dont understand why you can change the export properties though... odd one.
Arcam DV135, FMJ AV9, FMJ P7, B&W 704s, HMT7 and DS7s; Pioneer 506, Sky HD, Xbox 360, PS3, Wii, Sonos ZP80 & ZP100 - want a projector, but need a bigger room first
kevshed is offline   Reply With Quote
Old 30-10-2009, 10:14 PM   #3 (permalink)
Sorry, the material was shot on a Sony V1E in HD 1080i 25P frames per second, 16:9 (I think) PAL!
When I started the project I made sure I set it to the correct format (ie HD 1080i 25P)
I think its only when I burn it to DVD that it is so small?
I think the original resolution size was 1440X1080 or something along that?
If I start again, export it over again then which setting should I have? It seems there was no other setting that fit to my material other than the one I chose?
adobe, cs3, premiere, pro
[IMG] code is Off
