Hi there,
I live in UK PAL world, and I have some multi-format media which will eventually be combined into a single finished piece. I’m not assembling it myself so won’t get the headaches personally, I but don’t want to make things too onerous for the editor.
* An hour of Red footage, filmed at 4K 24fps;
* 20 minutes of Quicktime animations at 1920x1080, some of which may be able to render at 24fps, but some of it will be stuck at 25fps, not much I can do;
* 15 minutes of interview footage to be filmed, so the format isn’t set yet, but it will be shot on either a Z1 or EX1.
I’m not too bothered about the resolution of the interview footage, as it’s meant to be a visual contrast to the live action, but would you recommend shooting it at 24fps or 25fps? Can the Z1 and EX1 both handle 24fps?
I may also be editing the interview footage myself – nothing fancy, just cutting together sequences from a number of shots, and overlaying an additional audio track. I have access to a PC running Vista with an Intel Core 2 Duo 2.66GHZ and 4GB RAM – is this fast enough to edit Z1//EX1 footage, and is there any freeware that can help me do this?
Regards,
Tony
