| Re: Aspect Ratio Problem - Argghhhhhhh!!!
My first thought on your problem would have been to suggest that you should have your capture settings in your capture program set to 16.9, however you said that you had already done this.
Video editors gererally give the option to set the project at 16.9 or 4.3 before starting, it seems that Magix may be stuck in 4.3, magix could be relying on other codecs for this, I have no idea.
You could also try downloading a free trial of another editor like Corel Ulead Video Studio, it's fully functional has it's own capture program and will at least give you an idea of where your problem lies
