Originally Posted by joethomson86 my files are not mpeg-2 they are vob files how do you deal with this problem to convert they are all labelled as Video_TS or VTS_01_0 etc anyone know its a pain in the backside any help would be great |
VOB files
are mpeg2,
VOB (
Video
object) is the way they are "Packaged" so that normal DVD players can understand them. If you burnt a data disc with mpeg2 files, they would play on the PC but not a DVD player, A DVD video would play in either
If you get Software like Ulead DVD Movie Factory, and want to Create a Normal sized DVD, just pop in your miniDVDs in one after another , it will create a DVD video
Similarly you could do this by just copying the said vob files unto your HDD if you chose not to rename them as *.mpg
Your (mini) DVDs do not need ripping as this only applies to copy protected DVDs . You can simply pop itinto the DVD drive and copy the content to the PC's HDD
