Originally Posted by uzumaki_1 The things you've responded back from my comments havent helped anyone in this post. |
How?
I simply suggseted to the OP that he should be wary of comparing output from a £4000 camcorder ( which he did iby showing the clips) to those of the current consumer camcorders no matter how good they are
You also suggeseted he consider the SD 10 which he is doing
Making the point there is no perfect camcorder is by no means being unhelpful.
It is just saying that they all will have somewhere they dont perform perfectly but this may not matter to you
Also Canon make great kit but so do all the other brands
I don't know your background but some people think that the camcorders I suggested are really amatuer cams whereas I think there quite high spec cams.
Im not sure where or how my background matters ... The camcorders you suggeseted are good quality comsumer camcorders but by their very nature that is what they are. I have used them like them but Im aware of just how much to expect
Many struggle with low light indoors and unfortunately that is where we are most likely to use them
As it happens, Sony does make better models than the 105/106 and I would have thought Flash card camcorders are just as easy to download as HDD if not easier ( as per your suggestion) The card models also use less power and can be a little smaller.
There are good reasons for prefering one over the other but ease of downloading isnt one of them
For the price range starscream 22 is looking at i think they are good enough to perform for his needs. If you can justify buying a £4000 cam vs a £600 cam then fair enough.
Im not sure if you are getting my post in its real context It was not myself who posted up examples from the XLH1
I would read the last sentence in my post again..
Originally Posted by senu ...I just pointed out that the model the OP post You Tube videos on is a SemiPro/ high end Prosumer £4000 HDV ( tape) model with superior optics and electronics compared to many to the consumer camcorders you are suggesting. however, the Current AVCHD models have become quite impressive lately for the money |
From looking at the youtube videos you can film that same scene with a £600 cam, take it into after effects, put a gradient black circle effect on and give it a bleach bypass colour effect. I mean all of that is what makes the end result of the video looking good. If it werent for them effects then it wud be another HD video clip on youtube.
I agree .. Some one posted ( deleted now but in a new thread See link below ) quite impressive video from a Panasonic which is around £600 or just a bit more ; just to prove your point
Going off the point now what am trying to say is that its okay to spend £600 on a cam because you are going to get fantastic results...how you use the cam and lighting is what makes the footage seem less amatuer.
Correct
What is also true too is that when you spend a bit more you are less at the mercy of the camcorders limitations ( on auto settings) especially if it has a lot more manual control.
Better kit just makes it easier if you already have the know how
Im a little confused and not sure if you are not misinterpreting my post:
Nowhere in it is I am asking anyone to shell out £4000, just to be aware that in seeking the "perfect" one for £600 it is possible to look too hard
They are all generally very good , as long as one keeps expectations realistic
