can anyone help with finding a cheap sony minidv cam
Old 28-09-2009, 9:04 PM   #1
5,673, Level: 17
Points: 5,673, Level: 17 Points: 5,673, Level: 17 Points: 5,673, Level: 17
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1, Got 4
hi
just noticed currys/dixons appear to have dropped sony mini dv cams from their range. does anyone know where I could pick up a cheap sony mini dv cam , I really just want it as a player for transferring my dv tapes to pc
many thanks
cheers
Old 28-09-2009, 9:28 PM   #2
4,467, Level: 15
Points: 4,467, Level: 15 Points: 4,467, Level: 15 Points: 4,467, Level: 15
Thanks: Gave 24, Got 37
Re: can anyone help with finding a cheap sony minidv cam
I know there could be compatibility issues but this Samsung one is only £67
Samsung "VP-D381W/XEU" Mini DV camcorder - Very
Old 28-09-2009, 9:47 PM   #3
5,673, Level: 17
Activity: 2.3%
hi
thats a great price . however I was wondering if it would ruin my tapes (masters).............as I've read many times each cam manufacturer uses different compounds etc etc in their tapes and recording/playback heads
anyway thankyou for your efforts and speedy reply
Tinderbox (UK) (28-09-2009)
Old 28-09-2009, 10:47 PM   #4
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Unless the OP recorded LP there should be no compatibility issues . they are fairly standard
Its ok and probably even more cost effective not to specifically seek out a Sony model
Its easy to mix these thing up . The advise was to stick to one type of tape as there were some manufacturers using "wet" ( mainly Sony) and other's "dry" lubricants for the tapes
This may or may no tbe a thing of the past but it remains conventional wisdom not to mix and match tape brands
The issue is not with different camcorders it is with tapes.
For the purposes of playback (unless you recorded LP) there is absolutely no reason why a samsung camcorder will not play tapes recorded on a Sony and for recording you can use any tape wih any camcorde but ry and use the same brand as much as you can
HTH
Old 28-09-2009, 11:26 PM   #5
5,673, Level: 17
Activity: 2.3%
HTH
hi
the tapes are all sony , recorded in sp with a sony trv950e ,
Old 29-09-2009, 7:56 AM   #6
4,467, Level: 15
If you do decided to get the Samsung from Very, here are a couple of discount codes , XX580 20% , XX770 10%
Old 29-09-2009, 7:47 PM   #7
5,673, Level: 17
Activity: 2.3%
hi
thanks for that may I ask where you insert the codes ? couldnt see anywhere on the link?
Old 29-09-2009, 7:55 PM   #8
4,467, Level: 15
You need to make an account first.
Normally you add the product to your basket, then go to the checkout , you should see a box to enter the discount code.
EDIT : I ordered one myself , the first had a lot of motor/tape transport noise so i got a replacement the same model, and this one is great a lot quieter.
Originally Posted by stormchaser View Post
hi
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 6:30pm. Prices include delivery.
[IMG] code is Off
