| Re: Camcorder sports filming advice
I've done my fair share of filming parkour over the years, and whilst I'm not overly familiar with specific camcorder models around that price range, I can make some suggestions about things to look for in a camera. I'd say that the ability to use high shutter speeds is probably more important than actual frame rate. I've found that 25 or 30 FPS works fine for most things. Also, make sure you buy a camcorder which can take a wide angle lens. When you're shooting parkour in confined spaces, a wide angle lens allows you to fit more into the picture. This is useful in situations where you just can't get far enough back from the action to fit everything in frame with the standard lens. Try to resist to urge to go for a fish eye lens like so many people seem to. It's annoying to watch for prolongued periods, and gives a false sense of perspective.
I hope that helps.
Paul Maunder
