| Re: help with dvd
Not to sure about using the term Capture as in post #2 ,normally associated with linking a player and a recorder together or similar .All that is simply needed is a ripper , many free programs to do this job , this simply rip's the vob files to another format so you can edit them in a video edit package .Number1 , ShrinkDVD ,DVDFab ,just 3 of the many rippers about .Ripping your own DVD's is perfectly above board , it's only when folk start ripping bought DVD's does the piracy matter come into things.
As post #4 has pointed out , you can just copy the vob files to a folder on your hard drive but not all editing packages allow you to work with vob files .Womble and VideoReDo [ this is the one I use ] allow you to open and clip parts from vob files and save them as .avi or mpegs .
So , you could open each vob file ,one at a time ,clip ,edit the parts you want to keep and save them , then join all the bits together in your editing package and put onto DVD.
Another way to do it if you have access to a DVD/HDD recorder is to copy the DVD from disk to Hard Drive , then use the editing facilty to take out the bit you dont want . You would be left with a series of clips you could then join together and copy back to DVD . Of course , using this method means you can run as many copys as you like for friends and family without the need for a PC or editing package . I use a LiteOn DVD/HDD recorder and it makes quite a good job of things .
