8mm & Hi8 are old analogue formats. Hi8 is better quality than the even older 8mm. These camcorders are better in very low light conditions, but will loose a fair amount of quality when making copies.
Mini DV or often just called DV are a generic digital format used by most camcorder makers & therefore there is a very large choice of camcorders. Can be very good quality and this format is used by some TV news programmes etc for outside broadcasts. Most DV camcorders used by consumers are fairly poor at low light recording, but can be easily & cheaply copied onto a PC for editing etc and then copying to DVD-R etc with very little loss of quality.
Micro MV is a Sony only digital format. Many editing programmes can not be used with it. Tapes can be more difficault/expensive to get hold of. Tapes are very small, therefore so are the camcorders.
Digital 8 is another Sony only digital format. Can use Hi8 tapes to record digitally & some models can play back analogue recordings. Tapes are bigger, therefore so are the camcorders.
There are loads more pros & cons on the different formats, but this should get you going.
Mark.
