Originally Posted by mk Need help guys as totally fed up with trying to get the best quality content from the HC3E to DVD.
I have tried Vegas 9.0 on computer and can't get good quality. Best I can get is with Vista movie maker where it says its HD camcorder but images are jerky.
Purchase Sony 870 recorder and tried direct firewire dubbing but poor quality. Tried setting HDV-DV and every other setting with no luck.
Only thing left is HDMI to HDMI but need a lead.
Has anyone else got this hardware and getting good results ?  |
You cant cpture from the hdmi without a special adaptor it is hassle and not worth going that way with your model,if you are trying to make standard dvds
you will lose a lot of quality from your hd cam, avchd discs are hd quality and simple editing programns like pinnacle 12 ultimate will make them 35m on a single layer disc or there is the blu ray option but you need a bd burner, regarding the jerkiness if you are capturing via firewire in hd i can not explain the jerkyness it must be pc software related.
If it plays fine to a tv via hdmi and component but jerky when into your dvd recorder with the hdv dv set to on there could be a problem with the firewire socket or the firewire output, an easy test would be to connect the dvd recorder via standard dv and see how it plays.
