Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Latest popular product pricesPowered by
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Sanyo Xacti VPC-CG10
Canon Legria FS200
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Canon Legria FS200
Sony HDR-XR200VE 120GB
Canon Elura 60
Panasonic HDC-SD200
Sanyo Xacti VPC-FH1
Canon Legria HF200
Sony DCR-DVD150E
 More...Prices updated March 21st at 2:30am and include delivery.
Thread Thread Starter Forum Replies Last Post
Need a new mp3 player, thinking apple ipod classic 120gb? how is the sound quality? roblikesmusic Portable Music (MP3, iPod etc.) 49 22-09-2009 10:33 AM
Old 20-08-2009, 9:26 PM   #1 (permalink)
Does Video Quality Differ Between Hard Drive And SD Formats??
I've heard rumours that there are video quality differences between hard drive and sd card formats? I was wondering if anyone else has heard this? is it true?
Freezy is offline   Reply With Quote
Old 20-08-2009, 11:41 PM   #2 (permalink)
Thanks: Gave 495, Got 2,231
Re: Does Video Quality Differ Between Hard Drive And SD Formats??
The actual storage medium should not affect video quality provided the optics video processing and encoding are identical
What is true is that there may be a tendency to produce smaller file sizes for footage destined for cards whereas those going to HDD may not need to have such constraints
But bear in mind some camcorders actually record to both card and HDD and the output is identical
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 21-08-2009, 6:25 AM   #3 (permalink)
Thanks: Gave 4, Got 1
Yup.
MPEG 2 codec isn't that good.
I'm still cautious about the AVCHD codec.
Love Mini DV.
Old analog is just a pain with my computer editing software.
Mr Taylor is offline   Reply With Quote
Old 21-08-2009, 7:08 AM   #4 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 250
Not necessarily: HDV is mpeg-2, as are all standard definition DVDs, and almost all television broadcast.
Love Mini DV. Old analog is just a pain with my computer editing software.
Just to clarify for the OP as your post is ambiguous: mini-DV is digital video, not analogue.
These are the sort of windows faces look in at.
A n d r e w is offline   Reply With Quote
Old 21-08-2009, 7:34 PM   #5 (permalink)
Are we talking professional or home made situations?
(Good point about the Mini DV...the "DV" does stand for "Digital Video")
(Before that it was still tape but it was not digital, it was Analog)
The main point is that if you get a camcorder that writes to MPEG 2, chances are the quality will be be down from Mini DV.
This is a view gleaned by my own experiance and by reading the reviews on almost every camcorder on camcorderinfo.com.
I'm sure you can get Mpeg 2 to look great..but they they dont, not in consumer camcorders anyway.
Old 21-08-2009, 8:32 PM   #6 (permalink)
Thanks: Gave 6, Got 124
Believe me mpeg2 can look very good my experience with the sony HC-1,fx-7 and canon HV-30 prove that.
chrishull3 is offline   Reply With Quote
Old 21-08-2009, 9:17 PM   #7 (permalink)
Ohhhh..now I'm interested...I will keep an eye out for these cameras. thanks for the tip.!
Old 22-08-2009, 4:11 AM   #8 (permalink)
That HV canon you just mentiond has about a 1/2 inch sensor.
It must be prettty impressive!
What did it cost you?
Any defects?
how do the editing progs deal with the Mpeg 2 variation?
What file extension does it produce?
questions questions...
Old 22-08-2009, 6:45 AM   #9 (permalink)
Any defects?
The HV30 is now superseeded by the HV40 which in pal land is virtualy the same cam, i paid 530£ in the spring here in the uk,compared to the FX7 being a consumer cam it does not not have the same level of on cam controls and the lens is 10x not 20 like the FXs, what the HV30 has is progressive and cine mode which a lot of people like, personaly i keep to interlaced.
The only downsides are the onboard mic is poor[i use my RS external]the build quality gives the impression of being not as solid as sonys cams.
Editing i use pinnacle 12 ultimate which since the latest update has been better, editing mpeg 2 is easy there is no noticable loss in captured and finalised film. From this method hdv tape, blu ray disc, avchd disc and dvd discs can be made, i also store my material on hard drive.
Old 22-08-2009, 7:32 AM   #10 (permalink)
1/2.7" to be precise - better to round down to 1/3 than up to 1/2.
Old 22-08-2009, 10:10 AM   #11 (permalink)
Any defects?
The HV are HDV camcorders. This is hi def on tape and the mpeg is a different codec from SD mpeg2. It also has a fized encoding rate of 25mps and pixel size 1440 x 1820
The usual extension is m2t ( MPEG 2 with a transport stream header) not m2ts
Most current editng programs can edit it fluidly especially with more recent hardware
S3Stuff
Old 23-08-2009, 1:08 AM   #12 (permalink)
Now that is a crazy way to write a dimension.
Imperial and metric.
Still. it's pretty big.
I must get one of these cameras (second hand) to try it out.
Old 23-08-2009, 6:32 AM   #13 (permalink)
remember its hdv tape and i have given its downsides, you will need an external mic for good sound.
differ, drive, formats, hard, quality, video
[IMG] code is Off
Copyright © 2000-2010 M2N E. & O. E.
