| Sony DCR-TRV145E not operating
My Sony DCR-TRV145E is not operating apart from cassette insert/ejection.
In the display screen, a triangle above a horizontal line flashes & a beep sounds for five seconds...
According to the manual (p296, p299 & p331), moisture condensation has occurred. I've done what it suggests, more so... There is NO moisture in the camcorder.
There is a self diagnosis display which gives C:31:23.
On p301 it states 'A malfunction other than the above that you can service has occurred.'
Any ideas as to what to do or try next?
Cheers.
