Originally Posted by jippen Hello,
I own a hvr-z7 and the picture i get has a lot of grain (noise)...
Just show this example http://www.digitaleregioaalst.be/jippen/sonyhvrz7.m2t
Do i have some wrong settings , ore is there a problem with the camera?
Does someone have the same cam and can post an example ( .m2t) ?
Thanks for the help. |
You probobly need to set the sharpness down a bit, the sharper it is set the more grain there is in the picture , if it is already set low your cam may have a problem and it may need looking at.
