Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 6:30pm and include delivery.
AVCHD Question + Camcorder advice CasDon Camcorders and Video Editing 12 21-07-2009 5:24 PM
Formatted Sony RDR-HXD870 HDD Data Recovery Success !!! haydent DVD and Blu-ray Recorders, Recording and Media 1 20-07-2009 10:44 PM
Audio quality of Onkyo tx-sr876 toledo AV Amplifiers and Receivers 6 20-07-2009 11:49 AM
How's this for AVCHD editing?? Matty777 Camcorders and Video Editing 22 20-07-2009 9:17 AM
Looking for small TV's (22 inch) with quality panel Razenko LCD Televisions 5 20-07-2009 8:49 AM
Old 20-07-2009, 9:38 AM   #1 (permalink)
Thanks: Gave 368, Got 63
Converting AVCHD - Best formats for quality
Hi all, I have Just purchased a Panasonic HDC-SD1 (second hand) and I am really impressed with it. When plugged directly in via HDMI to my LCD TV or via MY Media player (WDTV as it plays .mts without converting) The quality is stunning.
I work with a Macbookpro and only currently have Imovie 06 which can't cope with the HD (Imovie 09 on order). So i am using handbrake to convert, but i am having problems with the quality after conversion.
Here is what option i have and need to know which container & codec will produce the best quality.:
Containers:
AVI
MP4
MKV
OGM
Codecs:
H.264 (x264)
Mpeg-4 (FFMprg)
Mpeg-4 (XviD)
VP3 (Theora)
Audio:
MP3 (lame)
AC3 Passthru (best as i have an amp that takes AC3?)
I find a 2-pass transcode produces better results.
Any help most appreciated on this as it's driving me insane
Cinema room spec: [eyes] Planar PD7010 - [ears] Samsung HTZ310R - [Heart] PS3
My Cinema Room Build...
deefadog is online now   Reply With Quote
Old 20-07-2009, 12:03 PM   #2 (permalink)
Thanks: Gave 15, Got 249
Re: Converting AVCHD - Best formats for quality
Two factors affecting the output quality of your video is the video bitrate, and the video resolution.
In order to keep the HD quality, you will need to make sure the resolution is large enough (1280x720 for 720p video, etc). What resolution settings have you used so far for your encodes?
If you set the bitrate too low, then you will get a poor quality output regardless of the resolution you choose. There may be presets available for HD video quality in Handbrake, but to be honest I've never actually used it.
"Take this quarter, go downtown, and have a rat gnaw that thing off your face!"
StevieBuck is offline   Reply With Quote
deefadog (20-07-2009)
Old 20-07-2009, 12:45 PM   #3 (permalink)
mmace's Avatar
Thanks: Gave 27, Got 61
for the best quality, don't convert it
if you're editing and exporting then hat's different, but if you're just converting then what's the reason for this?
Maff
mmace is offline   Reply With Quote
Old 20-07-2009, 12:49 PM   #4 (permalink)
Hi Steve, thanks for the info.
Basically i have kept the ratio the same which is - 1440 x 1080. It's a funny res they use, maybe that's my problem?
Here is what i found on the matter:
All Canon and Sony HDV camcorders record 1440 x 1080 using rectangular pixels.
Upon playback the image is properly scaled to 1920 x 1080 using square pixels.
On the bitrate i have tried to stick to around 18mps, as my WDTV media player has problems over 20mps. I have not tested these yet as i am in work.
The .mts files direct from the CamCorder are H.264/AVC 1440 x 1080, 25 fps - Audio DD 5.1 48000 Hz
So would it make sense to stick to the same H.264 codec along with all other settings, only the container would change, but whcih would be the best or does it not really matter?
mmace - My media player can play .mts files directly, but yes i will be editing them in imovie 09 (when i can afford it), not sure if i can save it back out as that, i will have to see. But for the time being i need to convert it to edit it, keeping the quality as best as i can close to the original.
Old 20-07-2009, 8:07 PM   #5 (permalink)
A n d r e w's Avatar
Thanks: Gave 31, Got 245
If you're converting the video in order to edit in iMovie HD, then if you can output as HDV, you'll not only maintain the same resolution as the native AVCHD files on the SD1, but you'll find that iMovie has an import preset for HDV.
I'm assuming that by iMovie 06 you mean imovie 06 HD - which can, as the name suggests, edit high definition video, just not AVCHD.
You might also want to google Voltaic HD, which will also give you a bunch of options for conversion.
These are the sort of windows faces look in at.
A n d r e w is online now   Reply With Quote
Old 22-07-2009, 2:25 PM   #6 (permalink)
mmace's Avatar
AVI is a container and can contain any number of codecs, 99.9% of which are compressed (like DV, DiVX, XviD etc)
Maff
Old 22-07-2009, 2:41 PM   #7 (permalink)
Thanks for the tips! I have checked out Voltaic & HD Video Converter. Had a few glitches with both regarding fails, bad quality etc - maybe have to play more. But i will hang fire until i get iMovie 09.
Does anyone know if with iMovie 09 you can export or save to .mts?
Old 22-07-2009, 8:15 PM   #8 (permalink)
Yes. You can't.
deefadog (22-07-2009)
Old 23-07-2009, 3:16 PM   #9 (permalink)
Thanks! Great information - much appreciated!
One more thing, more about the camcorder, does any capacity SD card work with this? As i am thinking of getting a 16GB or 32GB card, no issues?
Old 23-07-2009, 3:30 PM   #10 (permalink)
Should be fine - though a number of smaller cards is cheaper than one large card (and less grief if you have a card go belly up).
deefadog (23-07-2009)
Old 23-07-2009, 3:50 PM   #11 (permalink)
That's very true, although the Play have the 16Gb Cards for £17.99 delivered!
Old 27-07-2009, 1:00 PM   #12 (permalink)
Afternoon all!
Well ilife 09 arrived on the weekend and i have been playing around with imovie 09.
So i have many questions still, but thought i'd go through each individually.
One thing i would like cleared up is that the Panasonic SD1 records in 1440 x 1080 anamorphic. And from this quote i found on a review site:
"The HDC-SD5 and HDC-SX5 both record in 1920 x 1080 “full HD,” while the HDC-SD1 and HDC-DX1 top out at 1440 x 1080 anamorphic with a 1920 x 1080 output signal."
So does this mean when i import from the camera to imovie i am indeed importing a 1920 x 1080 video?
Old 27-07-2009, 1:04 PM   #13 (permalink)
I expect so, given that the output signal is listed as 1920x1080. You'll soon find out when you import a clip or two: if the picture looks squashed, then there's a problem. I imagine it'll work, though.
Old 27-07-2009, 1:22 PM   #14 (permalink)
Thanks, no the picture does not look squashed - it looks fine! Reason i ask is that on imovie o6 you could "apple i" each clip and it would tell you the dimensions, i can't find it on the 09 version
Also, as they state the output as 1920 x 1080 i was not sure they meant when imported from the camera or when outputted via hdmi to a TV. But as you say it would looked squashed otherwise then it must be outputted by both at 1920 x 1080.
I am still having problems exporting the movie to play correctly on my WDTV player, now this maybe the WDTV players fault. I have tried out putting using the "quicktime" option and have choosen a full quality avi, mpeg4, mov and still i get jumpy video or blurred edges or interlaced, when the imported video is as we have now established 1920 x 1080i and my HDTV is 1080i then i should not have the interlaced edging problem no?
EDIT
Well, I just found on the apple support site (imovie 09 compatibility chart) that -
"Panasonic HDC-SD1 - AVCHD - Memory - 1440 x 1080 will be imported as 960 x 540"
You can however change this to full - original size - but i get the warning - Selecting full on this computer may result in degraded video playback.
I have just got the info on the AIC / mov files that imovie transcodes to (which i imported as full) and they are 1440 x 1080.
So i must assume when we talked about the output being 1920 x 1080 it must be for play back to a TV via the HDMI cable?
Can anyone confirm any of this? think i am more lost LoL
Old 27-07-2009, 6:02 PM   #15 (permalink)
"Panasonic HDC-SD1 - AVCHD - Memory - 1440 x 1080 will be imported as 960 x 540" You can however change this to full - original size - but i get the warning - Selecting full on this computer may result in degraded video playback.
Ignore that and import as "full - original size" unless you find the clips just won't play back. Chances are they'll be fine.
I have just got the info on the AIC / mov files that imovie transcodes to (which i imported as full) and they are 1440 x 1080. So i must assume when we talked about the output being 1920 x 1080 it must be for play back to a TV via the HDMI cable?
Ah, of course, the 1440x1080 video will be using rectangular pixels at a ratio of 1.3:1, whereas 1920x1080 uses square pixels - hence your clips are still 16x9. I suppose that means that it's just when you hook your SD1 up to an HDTV that it outputs 1920x1080. Interesting.
Have you tried exporting using the H.264 codec, and seeing whether that looks okay played back on your WDTV?
deefadog (27-07-2009)
avchd, converting, formats, quality
[IMG] code is Off
