| Re: Sony TRV14E Upgrade
The SD200 and TM300 both use 3 1/4.1-inch CMOS sensors - about the same size as the CCD in your Sony (not sure whether yours has a single or three chips though). So they should both be on par with yours as far as shooting indoors goes. Of course, they're both high definition camcorders, so the picture should be markedly superior to anything you got out of the TRV14.
The TM300 has a few advantages over the SD200: dual memory (built-in flash memory as well as taking SDHC cards), a viewfinder, and a proper manual focus ring - these leap to mind.
I'd go for the TM300 if you can afford it.
__________________ These are the sort of windows faces look in at. |
