Originally Posted by bobbster
Hi Mark, thanks for the reply, if I chose the AT 897 I take it there is one XLR connection which I would pass through one channel of my MA300 is this correct?
Yes it has a single XLR output that means you can use any XLR lead to connect it to your camcorder.
I am new to this it just seems odd recording through one channel.
Well you can use 2 if you want, but as the PA will be (or should be!) mono it will just cost you more to buy 2 mics.
Many camcorders will add audio to both audio tracks when only one mic is connected (on mine it will do this with a mic to the left channel only).
Other suggestions I have has are the rode video mic
The Rhode Video Mic is Super-Cardioid. This means it will only be -10db at 90degrees (best rejection is at 120deg or greater) and will therefore still pick up a fair amount of noise from the sides (ie audience)
and AT pro 24,
This is a Cardioid mic and will pick up sound from basically all directions, so IMO this is not what you are after.
and again at the other end 2 x AKG C1000s,
these are cardioid to hypercardioid rather than directional.
but on the AKG's I read one review saying point these away from the speakers otherwise you will pick up feedback???
Cheers Bob
Any mic used for the PA will pick up feedback if pointed at a speaker unless it is filtered out with parametic EQ. However you mic(s) will not be part of the PA system so will not be able to form feedback.
Have a look at
This Web Site to see some of the pickup patterns of mics.
Mark.
