| Re: Wireless Clip Mic Advice
A radio mic will transmit the audio to a remote receiver that you would connect to a recording device.
However most radio mics will struggle to work at around 50m let alone 200m. Also most of the receivers will require a mains supply to work, but there are a few battery powered units around (well I've used them in the past).
I would suggest that at 200m between camera and the person being recorded you would be far better using a mic directly into a small DAT/minidisc etc recorder. These have the advantage that some models will record a SMPTE Time Code along with the audio that wil help sync the video and audio together when editing. I know miniDV camcorders also record SMPTE t/c but not sure if your camcorder does though.
Mark.
