First Camcorder purchase - advice needed!
Old 02-07-2009, 12:23 AM   #1
2,557, Level: 11
Points: 2,557, Level: 11 Points: 2,557, Level: 11 Points: 2,557, Level: 11
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 50, Got 11
Hi all,
I'm looking to take my first step into camcorders but i'm a bit confused about the different types/storage methods, etc.
Been looking at the hardrive cameras and the cameras that use memory sticks, etc.
Probably only looking to spend around the £200 mark.
Any opinions on differences/advantages between cameras with hard drives as opposed to memory stick types?
Only be using it for filming family, etc. Will i be just as well getting a decent cheap one or will i end up disappointed with features, etc?
I know i'm not being very specific here but just looking for a few options that maybe some fo you have bought and are happy with so i can check them out.
Thanks for any help!
Old 02-07-2009, 12:28 AM   #2
989, Level: 7
Points: 989, Level: 7 Points: 989, Level: 7 Points: 989, Level: 7
Thanks: Gave 26, Got 52
Re: First Camcorder purchase - advice needed!
if you have a HD tv, it would make sense to buy a HD camcorder, but remember for £200 you will probably get 5x optical zoom or less.
personally hybrid or SDHC/MSPD is better than just a hard drive. if you get just a hard drive camcorder and if it ever fails, you've pretty much lost all your recordings.
with flash memory you can always make up backups and store safely.
RoddyKFC (02-07-2009)
Old 02-07-2009, 2:14 AM   #3
2,557, Level: 11
Activity: 0.7%
Yeah never thought of that cheers. Is there anything specific in regards HD res/Features that i should look out for/avoid?
Old 02-07-2009, 11:50 AM   #4
2,454, Level: 11
Points: 2,454, Level: 11 Points: 2,454, Level: 11 Points: 2,454, Level: 11
Thanks: Gave 28, Got 4
hard drive - does give a good amount of storage, but can eat battery life and be susceptible to knocks.
sd card - less power-intensive than hard drive, and less prone to knocks.
flash memory onboard + sd card - best of both worlds
reckon you'll be hard pushed to keep to your budget. i was about to buy either the toshiba h20 or p30, but went for the panasonic sd20 in the end.
beware of the sony sd camera at around £30. a memory stick pro card with a good enough transfer rate for video will cost you upwards of £50. also, it's not High Def.
Old 02-07-2009, 4:55 PM   #5
2,557, Level: 11
Activity: 0.7%
Can i be cheeky and ask how much yours was/where you bought the sd20. Looks good. I think i could squeeze a bit moreout of the budget. Be disappointed to buy a cheaper one and not be happy with it!
Old 03-07-2009, 12:10 AM   #6
2,454, Level: 11
£330 - Currys. they're like hens teeth now though i think.
RoddyKFC (03-07-2009)
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 10:30am. Prices include delivery.
[IMG] code is Off
