Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Latest popular product pricesPowered by
Sony DCR-SR37E 60GB
Panasonic
Sanyo Xacti VPC-CG10
Canon Legria FS200
Sony DCR-SR37E 60GB
Panasonic
Canon Legria FS200
Sony HDR-XR200VE 120GB
Canon Elura 60
Panasonic HDC-SD200
Canon Legria HF200
Sanyo Xacti VPC-FH1
Panasonic SDR-S26
 More...Prices updated March 19th at 4:30am and include delivery.
Thread Thread Starter Forum Replies Last Post
Which DVD Player's support AVCHD format? Melanie S Camcorders and Video Editing 15 26-01-2010 12:16 PM
NEW : Sony HDR-TG3/TG1 - New Smallest 1080i camcorder Pt 2 senu Camcorders and Video Editing 349 26-12-2009 9:28 PM
HD Camcorder with Mic Input under 1000AUD? shizz Camcorders and Video Editing 5 01-07-2009 7:16 AM
Old 30-06-2009, 4:06 PM   #1 (permalink)
AVCHD vs HDV Camcorder Question(s)
Looking to buy my first high def camcorder...
Been told that AVCHD can be tempramental to edit and may place too much strain on my PC (core 2 duo processor 2.1Mhz and 2GB ram).
But I can't find many HDV camcorders at all. Best non-professional model I could find was the Sony HDR-HC9E (though no where seems to stock it).
1. Do any HDD or SD(HC) camcorders use HDV?
2. If I go for AVCHD would my PC specs be up to it (I am happy to get Sony Vegas 9 for editing, which apparently allows drag n drop of AVCHD clips)?
Thanks for any help you can give,
Phil.
phildavies79 is offline   Reply With Quote
Old 30-06-2009, 4:50 PM   #2 (permalink)
Thanks: Gave 6, Got 124
Re: AVCHD vs HDV Camcorder Question(s)
Phil.
[B]
Canon HV30 High Definition Mini DV Camcorder with remote [HV30] - £521.73 : Compudirect, Laptops, LCD Televisions, TFT Monitors, Digital Cameras and more..
Dont dicount this a great performer, my powerful quad core pc was not up to the job of properly editing avchd.
chrishull3 is offline   Reply With Quote
Old 30-06-2009, 5:27 PM   #3 (permalink)
Thanks: Gave 47, Got 12
I Have the earlier Canon HV20. Excellent camera as Chrishull3 says.
Ken42 is offline   Reply With Quote
Old 30-06-2009, 5:35 PM   #4 (permalink)
Thanks: Gave 495, Got 2,230
It will struggle
The Canons as suggested.
JVC made one or 2 which record HDv to HDD but Im not sure of current models
It is possible theoretically but would be hard to market because HDV would use up 13Gb for 1 hr of video
AVCHD would use up much les space for arguable the same or "better" quality Hi Def video
As stated above, it wiil strugle a lot
You could get a newer Quad core or i7 sysytem or stick with HDV for now
They all do
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 30-06-2009, 8:07 PM   #5 (permalink)
Thanks for the Cannon suggestion and the link.
Seems bizarre that most hi def camcorders are using AVCHD - a format that most folks are going to struggle editing. I would have thought people interested in hi def are also more likely to want to edit their footage.
One more question...
Can most high def camcorders (inc the Canon HV30) shoot in standard def as well? Or is it usually an either/or thing?
Thanks.
Old 30-06-2009, 8:43 PM   #6 (permalink)
[QUOTE]
A case of editing / software playing catchup with camcorders. The marketing was to et on tape high quality and affordable camcordein peoles hand first and worry about the smal minority seeking to edit later
Maybe soon, well have quad core i7 systems as entry level.. till then. AVCHD is very processor hungry
You can shoot SD but you can shoot HDV and capture as SD anyway as the camcorder can downconvert " on the fly" whist doing the capture
AVCHD camcorders cannot do this though so you either have to shhot Sd or convert in software later
Many Canon AVCHD models dont have SD shooting option
S3Stuff
avchd, camcorder, hdv, questions
[IMG] code is Off
Copyright © 2000-2010 M2N E. & O. E.
