Sony dcrsr37es.ceh
i have shortlisted the above camera,which has received fair reviews on Amazon but have not seen much elsewhere..
Any user comments/opinions before I take the plunge,I know battery is kinda of rubbish and need a spare one!!
My criteria is simplicity,hard disk basd and good optical zoom!!!
Product Features
Records up to 45 hours of high quality Standard Definition video on 60GB hard drive
Carl Zeiss Vario-Tessar lens with 60x optical zoom / 2000x digital zoom
SteadyShot image stabilization, Face Index and Film Roll Index
2.7” Wide LCD with easy to use touchscreen
Up to 11.5 hours STAMINA continuous shooting time (with optional battery)
Technical Details
Audio System Dolby Digital 2ch
Built in Microphone
Stereo, zoom microphone
Built in Speaker
Surround Recording
Camera-Image Device: Size 1 / 8" CCD
Advanced HAD technology
Number of Pixels Act Camera mode (K) 16:9 Mode . 490 / 4:3 Mode . 410
Focus: Full Range Auto
Focus: Manual
Manual Focus Key
Spot Focus (Touch Panel)Spot Meter
Minimum Illumination (lux) 6
SteadyShot (Image Stabilisation)(Electronic)
Shutter Speed 1/3-1/3500 (including Scene Selection)
White Balance Auto / Outdoor / Indoor / One-push
Scene Selection Twilight / Sunrise & Sunset / Fireworks / Landscape / Portrait / Spotlight / Sports (Movie only) / Candle / Beach / Snow
Auto Slow Shutter
Colour Slow Shutter
Backlight Compensation
Fader
Black / White
Telemacro
Number of Pixels Act Memory mode (K) 16:9 Mode . 310 / 4:3 Mode . 410
Camera Noise reduciton
Dimensions -Depth (mm) 105,Height (mm) 68,Width (mm) 60
Weight without Tape/Battery (g) 300
Audio Output - Video Output
S-Video Output
USB Output YES (USB 2.0 Hi-Speed)
Lens / Zoom-Lens Carl Zeiss Vario-Tessar F 1.8-6.0
F (Focal Distance) (mm) 1.8-108
F (35mm conversion): Camera mode (mm) 16:9 Mode . 39-2340 / 4:3 Mode . 44-2640
Filter Diameter (mm) 30
Zoom Ratio (Optical) 60
Zoom Ratio (Digital) 2000
Zoom Key
Lever / Button on LCD frame
F (35mm conversion): Memory mode (mm) 16:9 Mode . 49-2944 / 4:3 Mode . 44-2640
Still Image Recording
Still image recording on Memory Stick
PictBridge compatibility
Compression of still image JPEG
Recording Media
Memory Stick Duo
Memory Stick PRO Compatibility
Image Size: VGA
640 x 480
Index Playback
Still image recording on internal HDD
Others 16
Battery Info Demonstration Mode
InfoLITHUM System
Power Consumption : LCD (W) 2.2
Continuous Recording Time with Supplied Battery and LCD backlight off (min) 90
Max. Continuous Recording Time with Optional Battery and LCD backlight off (min) 710
Easy Handycam - Supplied Accessories:
View Finder / LCD Monitor
Hybrid LCD Screen LCD: Size (inch) 2.7
LCD: Pixels (dots) 123200
Touch Panel
Recorder/ Player
Movie Format Standard Definition, MPEG2
Recording Media 60GB Hard Disk Drive, Memory Stick
HYBRID (Movie rec on Memory Stick)
Movie Quality
HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Visual Index
Face Index
Film Roll Index
Playlist Edit
Add / Delete / Move
Original Edit Delete
One Touch Disc Burn Button
Playback Zoom
r
Ajex
