Originally Posted by Aeropars What I dont get is why, if my raw files are 1080i, am i not seeing combing on them yet i am after the edit. |
Most editing software doesn't show you the full quality video in the preview window. This almost always means if your source video is interlaced, you won't see the interlacing in the preview window. It's there, you just don't see it. Then you export, and you see it. It's not being added by the software, just hidden while previewing on the timeline or in the editing software's preview window.
Originally Posted by Aeropars I also dont understand why I would need to deinterlace. I've trawled the net but found no definative answer or tutorial on how i should approch this. |
You need to deinterlace in most cases if your video is destined for viewing on the web or any computer monitor because LCD computer monitors aren't designed to display interlaced video like television sets. On an LCD monitor the latency isn't the same as on a telelvision, meaning that you see each field as an individual whole, while on a television set they are more or less blended indiscernibly. Deinterlacing your video effectively turns it into progressive video, but at the expense of some of the information (because typically, deinterlacing drops every second field, which contains half of the horizonal lines of pixels making up a complete frame of video). But if you don't deinterlace, then you'll see the comb-like artefacts you're describing.
However, if your video is destined for viewing on a TV, then you needn't deinterlace because television sets are desgined to display interlaced video correctly.
