| Re: Best old Mini DV Camcorder for low light?
The Sony TRV-900e is excellent in low light conditions.
This cam was a prosumer model with full manual control and mine set me back around £1500 back in 2000. The 900 was replaced by the 950, but this cam was no where near as good in low light. The TRV-890 was exactly the same cam as the 900 but without AV-in enabled.
Generally speaking for good low light recording you want a large diameter of lens and large CCD's. 1 CCD will generally be better than 3 for low light, except on the higher range cams such as the 900 which has 3.
The big downside to the TRV-900 is that the cam records a 4:3 image, so widescreen will result in reduced resolution unless using an anamorphic lens attachment.
Mark.
