Anyway to prevent being host?
Old 22-11-2009, 2:01 PM   #1
3,172, Level: 13
Points: 3,172, Level: 13 Points: 3,172, Level: 13 Points: 3,172, Level: 13
Thanks: Gave 57, Got 34
Is there anyway to prevent me being a host on Modern Warfare 2?
I have a 10mb Virgin Media broadband download but upload is only 512k so it doesn't work when I'm host. I always seem to get picked though.
I've tried using wireless and ethernet and both are exactly the same
Old 23-11-2009, 8:45 PM   #2
3,172, Level: 13
anyone?
Old 23-11-2009, 9:04 PM   #3
8,989, Level: 22
Points: 8,989, Level: 22 Points: 8,989, Level: 22 Points: 8,989, Level: 22
Thanks: Gave 710, Got 833
I would have thought half-meg upload wasn't too bad? Mine is currently at about 300 on a 8mb connection?
Also, how do you know you are the host?
Old 23-11-2009, 9:16 PM   #4
3,172, Level: 13
when you start a game the host has all green bars whilst everyone else has red and then when it does the new migrate host thing after everyone moans of lagging I get kicked from the game
Old 23-11-2009, 9:18 PM   #5
13,710, Level: 28
Points: 13,710, Level: 28 Points: 13,710, Level: 28 Points: 13,710, Level: 28
Activity: 37.8%
Activity: 37.8% Activity: 37.8% Activity: 37.8%
Thanks: Gave 366, Got 817
512k upload should be fine. If you look at the amount of data used for gaming, it's actually pretty small.
Old 23-11-2009, 9:21 PM   #6
3,172, Level: 13
Heres a speed test
Old 23-11-2009, 9:21 PM   #7
3,172, Level: 13
Is it my router not liking all the connections or something then?
Old 23-11-2009, 9:27 PM   #8
Thanks: Gave 1,761, Got 1,379
Originally Posted by Ballgirl View Post
Heres a speed test
want me to host a few for you , i'm nearly always host , got 1.5Mb/s upload
need to restart the router though lol my download is sucky been online all day
Old 23-11-2009, 9:33 PM   #9
Illustrious Member
45,910, Level: 52
Points: 45,910, Level: 52 Points: 45,910, Level: 52 Points: 45,910, Level: 52
Activity: 84.5%
Activity: 84.5% Activity: 84.5% Activity: 84.5%
Thanks: Gave 1,843, Got 3,283
Its quite common that im host and it is normally suprisingly smooth
My connection:
Normally i get a slightly better DL eg 1.5Mb but either way, go figure
EDIT: Just re-ran it:
Old 23-11-2009, 9:45 PM   #10
4,045, Level: 14
Points: 4,045, Level: 14 Points: 4,045, Level: 14 Points: 4,045, Level: 14
Thanks: Gave 159, Got 120
Yeah mine isn't much better:
... and when I've been host it's been silky smooth. Have you tried ringing up your ISP and complain that you think the connection is a bit up and down?
Old 23-11-2009, 9:51 PM   #11
2,749, Level: 12
Points: 2,749, Level: 12 Points: 2,749, Level: 12 Points: 2,749, Level: 12
Thanks: Gave 65, Got 43
Borrow my interweb connection, I doubt I ever end up hosting.
That said it all seems quite lag-free the last few nights, have they fixed the matchmaking/host selection?
Old 23-11-2009, 9:56 PM   #12
3,760, Level: 14
Points: 3,760, Level: 14 Points: 3,760, Level: 14 Points: 3,760, Level: 14
Thanks: Gave 11, Got 29
I've found problems before when my connection looks ok on a speedtest, but it is dropping packets, which makes it laggy. Normally a router restart sorts that.
I found a way on my router of slowing down the sync speed. This sounds like it would mean a worse connection, but it seems that a lower sync speed gives a more stable connection. This is much more important for online gaming than bandwidth, as Sniper Ash stats show.
Old 23-11-2009, 10:00 PM   #13
Illustrious Member
45,910, Level: 52
Activity: 84.5%
I didnt mean to hi-jack the thread with speed tests, they should be left to What is your average connection speed?
I was merely making a point that it works in very weird ways as can be seen by my connection and the fact i get given host
Old 23-11-2009, 10:12 PM   #14
3,760, Level: 14
Ballgirl - I just noticed this website linked from speedtest.net: Pingtest.net - The Global Broadband Quality Test
That will tell you the quality of the line, not just the bandwidth. Probably more relevant for online gaming.
Old 23-11-2009, 10:20 PM   #15
1,471, Level: 8
Points: 1,471, Level: 8 Points: 1,471, Level: 8 Points: 1,471, Level: 8
Thanks: Gave 1, Got 5
I go through patches of being picked as host. I don't know why, when I am most of the other players only have 3/5 connection quality, and as I've mentioned a few times previously this is quite an advantage to me in one on ones.
I'd like to know if it's possible not be host, too. I know someone has said that the amount of data sent is pretty minimal but I'd like to know how minimal? I have a suspicion that if I'm hosting for more than an hour or so I hit Virgin Broadband's upload limit - which is 1400mb - and I get throttled.
Does anyone know if this is theoretically possible or if I'm barking up the wrong tree and hosting for even a long period won't get near that amount of data?
Mr_Ceee (09-12-2009)
Old 23-11-2009, 10:48 PM   #16
6,093, Level: 18
Points: 6,093, Level: 18 Points: 6,093, Level: 18 Points: 6,093, Level: 18
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 1,456, Got 675
Those speeds dont look right at all. Especially for a Be connection.
What package are you on?
Old 23-11-2009, 11:24 PM   #17
3,172, Level: 13
1% packet loss but I don't think thats too bad on a wireless internet connection. My xbox is connected to the router with an ethernet cable so should be no loss.
My router is wgt624v4. I've tried opening all the necessary ports and nothing helps. I've also tried the wgr614v9 that Virgin have given me and its the same
Old 23-11-2009, 11:30 PM   #18
3,720, Level: 14
Points: 3,720, Level: 14 Points: 3,720, Level: 14 Points: 3,720, Level: 14
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 115, Got 45
I've had this a few times this week, i'm also on Virgin 10mb!
Playing the other night, i have full 4 green bars, everyone else had 1! the game lasts about 1 minute evryone moans its lagging like a ****. It does the changing host thing, i end in the lobby on my own and have left my party where my mates are playing the same game i've just been kicked from!!
To add to this my router decides its gonna play up today and keeps disconnecting me from xbox live. Has to be restarted a couple of times to get going.
Just ordered some homeplugs tonight so will sort out the router issue I have.
Old 23-11-2009, 11:36 PM   #19
3,172, Level: 13
Let me know if the homeplugs help. Saying that I've tried my xbox direct to the virgin modem and it still did the same
Old 23-11-2009, 11:37 PM   #20
6,516, Level: 19
Points: 6,516, Level: 19 Points: 6,516, Level: 19 Points: 6,516, Level: 19
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 201, Got 191
I'm not with BT I'm with Post Office. All my internet use is wireless. I don't know what the solution can be,
Old 23-11-2009, 11:37 PM   #21
3,720, Level: 14
Activity: 1.3%
Ping looks good! Wireless on my laptop, luckily router is behaving itself at the moment!!
Old 23-11-2009, 11:44 PM   #22
3,720, Level: 14
Activity: 1.3%
Will do, hopefully should get them before the end of the week
Old 23-11-2009, 11:45 PM   #23
3,172, Level: 13
Just done another and better this time.
I have got a virgin media engineer coming out though as sometimes my connection does go completly
Old 23-11-2009, 11:49 PM   #24
2,855, Level: 12
Points: 2,855, Level: 12 Points: 2,855, Level: 12 Points: 2,855, Level: 12
Thanks: Gave 81, Got 117
I'm also having the same problem as others in this thread.. I get picked to be the host and the game lags for everyone apart from me
Is it only people on Virgin Media that are experiencing this?
I just unplugged the ethernet from my xbox and connected it to my laptop to test the connection and it seems to be running fine..
Old 23-11-2009, 11:52 PM   #25
15,448, Level: 29
Points: 15,448, Level: 29 Points: 15,448, Level: 29 Points: 15,448, Level: 29
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 46, Got 274
20mb line, I hope I never host with this
Edit
OMFG James, I dont get nowhere near ur download. Most I can hope to see is 14mb and nowhere near 20 ping.
Edit 2
Want a laugh check these out. They replaced the modem about 1-2 weeks ago.
http://www.pingtest.net/result/4212653.png
http://www.pingtest.net/result/4212782.png
http://www.pingtest.net/result/4212904.png
http://www.speedtest.net/result/631690040.png
http://www.speedtest.net/result/631691804.png
http://www.speedtest.net/result/631695260.png
Old 24-11-2009, 12:39 AM   #26
3,172, Level: 13
I've read on cableforum.co.uk that changing dns servers might help. Changed the ones on my router to be Open DNS servers 208.67.222.222 and 208.67.220.220 so will give that a try tomorrow
Old 24-11-2009, 2:37 AM   #27
Jay Jay is offline
53,744, Level: 56
Points: 53,744, Level: 56 Points: 53,744, Level: 56 Points: 53,744, Level: 56
Thanks: Gave 3,691, Got 2,325
You should want to be host, then you'll have the "host advantage" that this game favours.
Old 24-11-2009, 8:48 AM   #28
Location: On that ledge just under the broken window by that wall with the thingamy on.
4,002, Level: 14
Points: 4,002, Level: 14 Points: 4,002, Level: 14 Points: 4,002, Level: 14
Thanks: Gave 1,774, Got 320
To be fair I had never been host until last night, and lo and behold I come first for only the third time ever! And then Second Second. I usually come second from bottom or bottom in every game, so I definatley agree that there is a host adevantage!
Old 24-11-2009, 9:48 AM   #29
8,027, Level: 21
Points: 8,027, Level: 21 Points: 8,027, Level: 21 Points: 8,027, Level: 21
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 99, Got 126
I was in a lobby last night were I was host for the majority of it. I was raking in the kills for most games (still couldn't beat my 9 killstreak though ). Connection quality dominates this game I've found.
Old 08-12-2009, 8:22 PM   #30
2,855, Level: 12
This is getting on my nerves now, there's nothing wrong with my connection from what I can see but I can't host matches at all Basically when the game starts and I'm the host, everyone is on a 1 bar connection, apart from me and then 10 seconds later I get kicked back into the lobby.
What makes it worse is that nearly everytime I'm in the pre-match lobby and the host leaves, I will be picked as the host for the next game.. So I have to leave the match if it starts looking for a new host
