Heartbeat Sensor with Scope
Old 22-11-2009, 9:49 AM   #1
paper-kuts's Avatar
2,352, Level: 11
Points: 2,352, Level: 11 Points: 2,352, Level: 11 Points: 2,352, Level: 11
Thanks: Gave 0, Got 3
I'm only ranked about 15 at the moment and was wondering if at some point (at the right rank), if it's possible to use the heartbeat sensor AND laser/acog scope on the same weapon simultaneously??
Old 22-11-2009, 9:56 AM   #2
Illustrious Member
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
No need for a new thread....depending on your gun, yes you will be able to do so with the Bling Perk.
Old 22-11-2009, 10:23 AM   #3
paper-kuts's Avatar
2,352, Level: 11
Thank.
Apologies if a new thread wasn't necessary.
Paper
