COD MW2 Tournament
Old 19-11-2009, 2:16 PM   #1
ODP ODP is offline
ODP's Avatar
17,339, Level: 31
Points: 17,339, Level: 31 Points: 17,339, Level: 31 Points: 17,339, Level: 31
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 971, Got 889
COD MW2 Tournament
Ha'way then, whos gonna sort one out??
Old 19-11-2009, 2:19 PM   #2
1,373, Level: 8
Points: 1,373, Level: 8 Points: 1,373, Level: 8 Points: 1,373, Level: 8
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 34, Got 13
I'm not sure how you'd go about setting one up.. but when it's going, count me in
Old 19-11-2009, 2:27 PM   #3
3,128, Level: 13
Points: 3,128, Level: 13 Points: 3,128, Level: 13 Points: 3,128, Level: 13
Thanks: Gave 27, Got 40
I may be interested in taking part in this, cos I only have 1 or 2 of you on my list & wanna get to know more ppl
how would it work?
teams? cage matches?
Old 19-11-2009, 2:30 PM   #4
ODP ODP is offline
ODP's Avatar
17,339, Level: 31
Activity: 9.5%
how would it work?
COD : Modern Warfare - FFA Tournament
take a look at the one we had a few months ago for COD4 set up by Tones,
All went well despite my pathetic performance
Old 19-11-2009, 2:32 PM   #5
3,128, Level: 13
haha FFA i'd get my ass kicked
how about small teams, like a mini world cup, that could be fun
Old 19-11-2009, 2:35 PM   #6
17,362, Level: 31
Points: 17,362, Level: 31 Points: 17,362, Level: 31 Points: 17,362, Level: 31
Activity: 10.8%
Activity: 10.8% Activity: 10.8% Activity: 10.8%
Thanks: Gave 2,058, Got 1,127
Sowt it out Tones Although maybe give it date quite in advance so we can all get some decent practise in
Old 19-11-2009, 2:36 PM   #7
ODP ODP is offline
ODP's Avatar
17,339, Level: 31
Activity: 9.5%
might be a little hard to balance.. imagine Bearman,Guns and Ennis on a team if you will
Old 19-11-2009, 2:38 PM   #8
3,128, Level: 13
ok fair enough
Old 19-11-2009, 2:45 PM   #9
2,986, Level: 12
Points: 2,986, Level: 12 Points: 2,986, Level: 12 Points: 2,986, Level: 12
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 35, Got 66
would be good fun.
i'd be up for it.
Old 19-11-2009, 3:33 PM   #10
Location: On that ledge just under the broken window by that wall with the thingamy on.
4,002, Level: 14
Points: 4,002, Level: 14 Points: 4,002, Level: 14 Points: 4,002, Level: 14
Thanks: Gave 1,774, Got 320
How about each team has 3 people on it, 1 player with KD of over 1.3, one between 1.3 - 0.9, then 0.9 and under?
Then we wouldn't have unfairly balanced teams!
Or maybe not.
Old 19-11-2009, 3:36 PM   #11
ODP ODP is offline
ODP's Avatar
17,339, Level: 31
Activity: 9.5%
Or maybe not.
Good luck to whoever trys to set that up
Old 19-11-2009, 3:45 PM   #12
2,986, Level: 12
Activity: 1.0%
how bout a knockout cage match style?
randomly drawn, round matches has to be played by a certain date, game sorted out through here.
Old 19-11-2009, 3:47 PM   #13
2,720, Level: 12
Points: 2,720, Level: 12 Points: 2,720, Level: 12 Points: 2,720, Level: 12
Thanks: Gave 23, Got 74
Hi guys I would happily set it up if you want me to.
The best thing to do would have small 3v3 matches as mentioned with the KD ratio as part of the seeding system.
I think Seed 1 should be anyone with a KD - 1.30 and over.
Seed 2 KD-0.80-1.29
Seed 3 Less than 0.80
If you guys want me to do this then I will happily set it up...just give me the thumbs up and ill start another thread asking for JUST your KD ration.
There will obviously be a closing date so that after that i can focus on getting the teams sorted.
Obviously would need to know what game type there is to play etc etc.
Old 19-11-2009, 3:49 PM   #14
50,196, Level: 54
Points: 50,196, Level: 54 Points: 50,196, Level: 54 Points: 50,196, Level: 54
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,070, Got 2,048
I'd be interested... Seeding the way to go too!
I can help out with the admin if needed, I have tourney experience.
Old 19-11-2009, 3:55 PM   #15
15,776, Level: 30
Points: 15,776, Level: 30 Points: 15,776, Level: 30 Points: 15,776, Level: 30
Thanks: Gave 413, Got 224
I'm in for a team torunament.
The old GOW tourneys worked well having squads of 6 or 7 and then you played in teams of 4, rotating your players. That had players seeded as well.
I'm rubbish
Old 19-11-2009, 3:56 PM   #16
virtual22's Avatar
17,872, Level: 32
Points: 17,872, Level: 32 Points: 17,872, Level: 32 Points: 17,872, Level: 32
Thanks: Gave 460, Got 773
Seed 2 KD-0.80-1.29
I'd be in for this.
If you're going to do a table system though, to make it as easy and fair as possible you could say every team plays every other team home and away. The home team decides game type, whether or not perks, kill streaks etc. are on or off and the map. That way every team gets to play a map and game type that suits their strengths. I for example would be totally rubbish at FFA or TDM but might be a little better at domination or something like that.
Old 19-11-2009, 3:58 PM   #17
6,953, Level: 19
Points: 6,953, Level: 19 Points: 6,953, Level: 19 Points: 6,953, Level: 19
Thanks: Gave 94, Got 150
I would be up for this.
Old 19-11-2009, 3:59 PM   #18
3,252, Level: 13
Points: 3,252, Level: 13 Points: 3,252, Level: 13 Points: 3,252, Level: 13
Activity: 0.7%
Thanks: Gave 157, Got 160
What about just going a total team K/d ratio < 3 rule,
Be alot easier to set up as people can setup there own team.
Old 19-11-2009, 4:01 PM   #19
2,720, Level: 12
Yer totally agree..
Each team gets to host, but the non hosters should get to choose the game type and rules etc etc.
Do you think all game types should be in ?
Do you think the game options should be limited ? such as having only headshots etc, or should there be a set off rules that all games have ?
Old 19-11-2009, 4:03 PM   #20
3,249, Level: 13
Points: 3,249, Level: 13 Points: 3,249, Level: 13 Points: 3,249, Level: 13
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 49, Got 28
you can add me to a team based tourny too, thanks.
Old 19-11-2009, 4:04 PM   #21
virtual22's Avatar
17,872, Level: 32
Yer totally agree..
I'd say the fewer rules the easier the tournament will be to run, set up and manage. That's why I'd just say to the home team, set it up how you want it. Every team will play the same number of home and away games after all
Old 19-11-2009, 4:05 PM   #22
3,252, Level: 13
Activity: 0.7%
Yer totally agree..
I think we should just stick to the standard Rules used in the ranked matches to keep it even.
Old 19-11-2009, 4:06 PM   #23
2,720, Level: 12
Virtual----
But having the hosting team setting up a game of their choice would play into the hosts favour...I remember being host on call of duty 4 and my god do you know when your host ?
Also in the event of a draw what would happen to decide who wins....
Im just trying to get all the information together in one forum so that i can create a seperate post with the rules in so people can post KD ration and i can get it under way.
DIEEASYSTEVE...I agree with that, although 3v3 team death match may take a long while to do maybe reduce that a bit.
Old 19-11-2009, 4:10 PM   #24
3,249, Level: 13
Activity: 1.2%
i think its best to keep the game mode rules the same as they are in ranked matches. As everyone will be used to them.
Old 19-11-2009, 4:11 PM   #25
virtual22's Avatar
17,872, Level: 32
Virtual----
I don't know to be honest mate, I'm just having a really boring day at work and chucking ideas at this is far more interesting I should really just leave it up to the people who have played a COD tournament before really as they'll have some experience
Old 19-11-2009, 4:15 PM   #26
2,720, Level: 12
Right Im going to start a seperate post asking for KD so we can get it underway.
If people want to add me on xbox it is:
Special Needs x
Old 19-11-2009, 4:29 PM   #27
3,249, Level: 13
Activity: 1.2%
i know where your ideas are coming from mate, the good old days of gears. That tourny was a classic.
Old 19-11-2009, 4:38 PM   #28
Location: Apples and Pears, Any Old Iron, doing the Lambeth Walk....Oi!
2,698, Level: 12
Points: 2,698, Level: 12 Points: 2,698, Level: 12 Points: 2,698, Level: 12
Activity: 0.7%
Thanks: Gave 53, Got 18
how would it work?
Hello There, I'm not good enough for tournaments LOL but you can add me if you want to play with fellow AVF members, just make sure you add the clan tag in the game to AVF otherwise if you join a room full of AVF members you will be asked to leave........ politely of course :
Simples!!
Old 19-11-2009, 4:49 PM   #29
1,459, Level: 8
Points: 1,459, Level: 8 Points: 1,459, Level: 8 Points: 1,459, Level: 8
Thanks: Gave 6, Got 2
I know I'm the new guy but do you mind if I join in?
Old 19-11-2009, 4:50 PM   #30
2,720, Level: 12
I have know set up another thread where you can all join.
Hopefully it can be made a sticky or something ?
