Spec Ops Connection Problems
Old 18-11-2009, 1:49 AM   #1
1,093, Level: 7
Points: 1,093, Level: 7 Points: 1,093, Level: 7 Points: 1,093, Level: 7
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 7, Got 0
Has anyone else had problems playing Spec Ops online? I tried earlier and the screen constantly skipped all over the place!
Old 18-11-2009, 6:37 AM   #2
jamienufc's Avatar
11,983, Level: 26
Points: 11,983, Level: 26 Points: 11,983, Level: 26 Points: 11,983, Level: 26
Thanks: Gave 334, Got 369
Re: Spec Ops Connection Problems
I had connection problems yesterday.
Jumped into a mp game with a friend and I began to lag really bad, to the point it was un-playable. I quit out and ran a speedtest on my pc and got 16mbps download speed and 40 ms ping
We then decided to play spec ops and I got the lag again, not as bad as in mp, but noticable. After playing for about an hour the game wouldn't let me connect to my friend anymore, despite multiple invites and quitting back to the dash. In the end we gave up.
I'm not sure what the cause is, but noticed my NAT is set to moderate. Not sure how to change this because in my router set up, my NAT is open.
Anyone else having connection/lag issues online?
I'm playing over a wired setup using a Netgear router if that helps?
Jamie
