Modern Warfare 2 FAQ v2.5: Maps, Perks, Ranks, Weapons, Challenges & More!
| | Post Reply |
| | #1 |
| Moderator/Games Reviewer | Modern Warfare 2 FAQ v2.5: Maps, Perks, Ranks, Weapons, Challenges & More! Advertisement Want to Advertise?
Here is the second attempt at an FAQ for MW2, its by no means complete, if you spot any mistakes or have any info to add or request please post away, your input is appreciated! Last edited by Guns_LotsOfGuns; 31-03-2010 at 12:41 PM. Reason: Added ranks, prestige, icons & xp! |
| Quote |
| Thanks from: | 1LeeDenton (19-11-2009), alan280170 (18-11-2009), Andy58 (16-11-2009), AVF Jazzy Geoff (17-11-2009), Baked (19-09-2010), bananaman (26-11-2009), bearman3784 (20-11-2009), Bowders (14-12-2009), brumhee (16-11-2009), CARLOS (21-01-2010), chewyx (10-12-2009), DJ Ovengloves (28-12-2009), DongaTon (20-11-2009), dpb69 (18-11-2009), EEC3 (16-11-2009), erniebert1 (18-11-2009), FightingPrice (26-11-2009), Greasychipbutty (16-11-2009), Hors1na (27-11-2009), hybridkit (20-11-2009), i_don't_care (26-01-2010), JazzyFonze (16-11-2009), jimmiknicks (27-11-2009), JuanRCP (16-11-2009), kav (16-11-2009), King Tones (16-11-2009), kopchoir (19-11-2009), Lalonde (29-12-2009), mickem07 (04-12-2009), mossym (16-11-2009), Mr H Shingles (20-11-2009), MrSmiley (16-11-2009), Munkey Boy (19-11-2009), ODP (25-11-2009), Peew971 (17-11-2009), qwerty321 (16-11-2009), reddevil63 (16-11-2009), Rorifett (01-01-2010), Spunky_Monkey (23-12-2009), Stealth Rodeo (16-11-2009), stormberg (27-03-2010), Stream62 (16-11-2009), thefamoushoops (23-11-2009), Warchild1973 (16-11-2009), Zooks (24-11-2009) |
| | #2 |
| Moderator/Games Reviewer | Multiplayer Maps Removed for the moment Last edited by Guns_LotsOfGuns; 31-03-2010 at 12:17 PM. |
| Quote |
| Thanks from: | alan280170 (24-12-2009) |
| | #3 |
| Moderator/Games Reviewer | Perks Perk 1 Marathon: Unlimited sprint (Start) Marathon Pro: Climb obstacles faster - Sprint 26 miles with Marathon Sleight of Hand: Faster reloading (Start) Sleight of Hand Pro: Faster aiming down the sights - Get 120 kills with Sleight of Hand Scavenger: Resupply from dead enemies (Lv. 13) Scavenger Pro: Extra magazines - Resupply 100 times while using Scavenger Bling: Two primary weapon attachments (Lv. 21) Bling Pro: Two secondary weapon attachments - Get 200 kills using a weapon with 2 attachments One Man Army: Swap classes at any time; switch takes five seconds and replaces secondary weapon (Lv. 45) One Man Army Pro: Swap classes faster - Get 120 kills using One Man Army Perk 2 Stopping Power: Increased bullet damage (Start) Stopping Power Pro: Extra damage against enemy vehicles (helicopters, AC-130s, etc.) - Get 250 kills using Stopping Power Lightweight: Move faster (Start) Lightweight Pro: Quicker aim after sprinting - Sprint 30 miles using Lightweight Hardline: Kill Streaks require one less kill (Lv. 9) Hardline Pro: Death Streaks require one less death - Get 40 killstreaks while using Hardline Cold-Blooded: Undetectable by UAVs, air support, sentries and thermal (Lv. 25) Cold-Blooded Pro: No red crosshair or name when targeted - Destroy 40 enemy killstreak rewards using Cold Blooded Danger Close: Increased explosive weapons damage (Lv. 33) Danger Close Pro: Extra air support damage - Get 100 kills with explosives while using Danger Close Perk 3 Commando: Increased melee distance (Start) Commando Pro: No fall damage - Get 20 melee kills while using Commando Steady Aim: Increased hip-fire accuracy (Start) Steady Aim Pro: Longer hold-breath duration - Get 80 hipfire kills using Steady Aim Scrambler: Jams enemy radar near the player (Lv. 17) Scrambler Pro: Delay enemy claymore explosions - Get 50 close range kills using Scrambler Ninja: Invisible to Heartbeat Sensor (Lv. 29) Ninja Pro: Footsteps are silent - Get 50 close range kills using Ninja SitRep: Detect enemy explosives and Tactical Insertions (Lv. 37) SitRep Pro: Louder enemy footsteps - Destroy 120 enemy devices using SitRep Last Stand: Fall to the ground and use a secondary weapon until bleeding out (Lv. 41) Last Stand Pro: Allows use of equipment while in Last Stand Last edited by Guns_LotsOfGuns; 20-11-2009 at 2:13 PM. |
| Quote |
| | #4 |
| Moderator/Games Reviewer | Killstreaks 3 Kills -- UAV This deploys a UAV (unmanned aerial vehicle) that shows the enemies on the radar as dots. The UAV can be shot down by the enemy. This can be blocked with the Cold-Blooded perk. 4 Kills -- Care Package After you throw the red signal flare, the Care Package will be airdropped into the battlefield. This can be picked by anyone, even the enemy. The package contains either a random killstreak or ammo. The killstreak can be anything from the UAV to the EMP, regardless what killstreak rewards you have chosen. 4 Kills -- Counter UAV This disables the enemy radar for a short period of time, even if they don't have a UAV in the air. 5 Kills -- Sentry Gun Airdrops a placeable XM312 Sentry Gun that will automatically fire at enemies. It can be destroyed by normal means, or temporarily disabled with Flashbangs and Stun Grenades. The Sentry Gun has a 90 degree turn on its turret and can pitch up and down. You can move the Sentry Gun around even after you've deployed it, but it won't fire until it's placed. They are most effective when placed in high places. 5 Kills -- Predator Missile This allows you to remote control a Predator missile. After opening the laptop, you have approximately 5 seconds to control the missile to your target, as it goes down. You can also give the missile a boost to make it go down faster. You are vulnerable while using the Predator missile, but if you get killed, you can still continue to control it. 6 Kills -- Precision Airstrike This is much like the Airstrike from Call of Duty 4, but this time you can control the direction of the Airstrike for more accurate kills. 7 Kills -- Strike Airstrike with a hovering Harrier. After dropping its bombs, the Harrier will guard the area for a short period of time. 7 Kills -- Attack Heli Deploys a helicopter to the battlefield like in Call of Duty 4. It will circle the map and automatically attack the enemies for a few minutes and leave. It can be destroyed with guns and missiles. All the enemies that it kills are added to your kill count. 8 Kills -- Emergency Airdrop Airdrops 4 random killstreaks or ammo. This is the same as the Care Package, but x4. 9 Kills -- Pave Low This deploys a heavily armored Attack Helicopter (Sikorsky MH-53 Pave Low) to the map for maximum carnage. As with the Attack Helicopter, all the kills are added to your kill count. 9 Kills -- Stealth Bomber Calls in a Stealth Bomber (B-2 Spirit) to carpet bomb the selected area. You can also control the direction, just like with the Precision Airstrike. The airstrike doesn't show on enemy radar. 11 Kills -- Chopper Gunner Be the gunner of an attack helicopter. The chopper will fly around the map and you can remotely control the 25mm gun with your laptop. 11 Kills -- AC-130 After the AC-130 Gunship is deployed via laptop, it will enter the map. You control it remotely for 30 seconds and you can use the 25mm, 45mm and 105mm guns to shoot at enemies. You are vulnerable while controlling the AC-130, but if you get killed while using it, you can still continue. Note: The AC-130 can be shot down by the enemy, but it does have flares as countermeasures. 15 Kills -- EMP Electromagnetic pulse or EMP for short. Temporarily disables enemy electronics like the Thermal Scope, Red Dot Sight, etc. The EMP also stops the enemy from using killsreaks and at the same time drops down any helicopters and aircrafts that are in the air. 25 Kills -- Tactical Nuke Gives you and your team an instant win. The Tactical Nuke ends the match with a bang by killing everyone on the map. Last edited by Guns_LotsOfGuns; 20-11-2009 at 2:14 PM. |
| Quote |
| | #5 |
| Moderator/Games Reviewer | Deathstreaks 4 deaths - Copycat: Copy the loadout (Weapons, Perks, and Attachments) of the enemy that killed you last. (Start) 3 deaths - Painkiller: Double health for ten seconds after respawn. (Lv. 6) 4 deaths - Martyrdom: Drop a live grenade when killed. (Lv. 27) 4 deaths - Final Stand: Crawl around on the ground with any weapon before dying; full recovery if no damage is taken for a certain amount of time. (Lv. 39) Last edited by Guns_LotsOfGuns; 20-11-2009 at 2:15 PM. |
| Quote |
| | #6 |
| Moderator/Games Reviewer | Weapons Unlocks Assault Rifles • M4A1 (default) • FAMAS (lvl 4) • SCAR-H (lvl 8) • TAR-21 (lvl 20) • FAL (lvl 28) • M16A4 (lvl 40) • ACR (lvl 48) • F2000 (lvl 60) • AK-47 (lvl 70) Sub-Machine Guns • MP5K (default) • UMP45 (default) • Vector (lvl 12) • P90 (lvl 24) • Mini-Uzi (lvl 44) Light Machine Guns • L86 LSW (default) • RPD (default) • MG4 (lvl 16) • AUG HBAR (lvl 32) • M240 (lvl 52) Sniper Rifles • Intervention (default) • Barret .50cal (default) • WA2000 (lvl 36) • M21EBR (lvl 56) Riot Shield (default) Machine Pistols • PP2000 (default) • G18 (lvl 22) • M93 Raffica (lvl 38) • TMP (lvl 58) Shotguns • SPAS-12 (default) • AA-12 (lvl 18) • Striker (lvl 34) • Ranger (lvl 42) • M1014 (lvl 54) • Model 1887 (lvl 67) Handguns • USP .45 (default) • .44 Magnum (lvl 26) • M9 (lvl 46) • Desert Eagle (lvl 62) Launchers • AT4-HS (default) • Thumper x 2 (lvl 14) • Stinger (lvl 30) • Javelin (lvl 50) • RPG-7 x 2 (lvl 65) Equipment • Frag (default) • Semtex (default) • Throwing Knife (lvl 7) • Tactical Insertion (lvl 11) • Blast Shield (lvl 19) • Claymore (lvl 31) • C4 (lvl 43) Attachments • Grenade Launcher • Red Dot Sight • Silencer • ACOG Scope • FMJ • Shotgun • Holographic Sight • Heartbeat Sensor • Thermal • Extended Mag • Akimbo (Allows players to dual wield Pistols, Machine Pistols, the Ranger shotgun, and Sub Machine Guns) Special Grenades • Flash Grenade x 2 • Stun Grenade x 2 • Smoke Grenade x 1 Camo's • Desert • Artic • Woodland • Digital • Urban • Blue Tiger • Red Tiger • Fall Weapon Damage Chart ![]() Last edited by Guns_LotsOfGuns; 14-12-2009 at 8:00 AM. |
| Quote |
| | #7 |
| Moderator/Games Reviewer | Ranks ![]() ![]() ![]() Last edited by Guns_LotsOfGuns; 20-11-2009 at 2:18 PM. |
| Quote |
| | #8 |
| Moderator/Games Reviewer | Playlists
| Quote |
| | #9 |
| Moderator/Games Reviewer | Last edited by Guns_LotsOfGuns; 20-11-2009 at 2:19 PM. |
| Quote |
| | #10 |
| Moderator/Games Reviewer | Challenges All Challenges except for Gun specific challenges & Prestige challenges are listed below - Perk Challenges Marathon Pro Challenge Part 1 - 500 XP Part 2 - 1000 XP Part 3 - 2500 XP Part 4 - 5000 XP Part 5 - 10000 XP Part 6 - 10000 XP Scavenger Pro Challenge Part 1 - Resupply 10 times - 500 XP Part 2 - Resupply 25 times - 1000 XP Part 3 - Resupply 50 times - 2500 XP Part 4 - Resupply 100 times - 5000 XP Part 5 - Resupply 250 times - 10000 XP Part 6 - Resupply 500 times - 10000 XP Bling Pro Challenge Part 1 - 25 kills while using Bling - 500 XP Part 2 - 50 kills while using Bling - 1000 XP Part 3 - 100 kills while using Bling - 2500 XP Part 4 - 200 kills while using Bling - 5000 XP Part 5 - 450 kills while using Bling - 10000 XP Part 6 - 900 kills while using Bling - 10000 XP One Man Army Pro Challenge Part 1 - 15 kills while using perk - 500 XP Part 2 - 30 kills while using perk - 1000 XP Part 3 - 60 kills while using perk - 2500 XP Part 4 - 120 kills while using perk - 5000 XP Part 5 - 300 kills kills while using perk - 10000 XP Part 6 - 750 kills while using perk - 10000 XP Sleight of Hand Pro Challenge Part 1 - 15 kills while using perk - 500 XP Part 2 - 30 kills while using perk - 1000 XP Part 3 - 60 kills while using perk - 2500 XP Part 4 - 120 kills while using perk - 5000 XP Part 5 - 300 kills while using perk - 10000 XP Part 6 - 750 kills while using perk - 10000 XP Stopping Power Pro Challenge Part 1 - 30 kills while using perk - 500 XP Part 2 - 60 kills while using perk - 1000 XP Part 3 - 120 kills while using perk - 2500 XP Part 4 - 250 kills while using perk - 5000 XP Part 5 - 500 kills while using perk - 10000 XP Part 6 - 1000 kills while using perk - 10000 XP Hardline Pro Challenge Part 1 - 3 killstreaks while using perk - 500 XP Part 2 - 10 killstreaks while using perk - 1000 XP Part 3 - 20 killstreaks while using perk - 2500 XP Part 4 - 40 killstreaks while using perk - 5000 XP Part 5 - 100 killstreaks while using perk - 10000 XP Part 6 - 250 killstreaks while using perk - 10000 XP Lightweight Pro Challenge Part 1 - 500 XP Part 2 - 1000 XP Part 3 - 2500 XP Part 4 - 5000 XP Part 5 - 10000 XP Part 6 - 10000 XP Cold Blooded Pro Challenge Part 1 - Destroy 3 killstreak rewards while using perk - 500 XP Part 2 - Destroy 10 killstreak rewards while using perk - 1000 XP Part 3 - Destroy 20 killstreak rewards while using perk - 2500 XP Part 4 - Destroy 40 killstreak rewards while using perk - 5000 XP Part 5 - Destroy 100 killstreak rewards while using perk - 10000 XP Part 6 - Destroy 250 killstreak rewards while using perk - 10000 XP Danger Close Pro Challenge Part 1 - 10 kills with explosives while using perk - 500 XP Part 2 - 25 kills with explosives while using perk - 1000 XP Part 3 - 50 kills with explosives while using perk - 2500 XP Part 4 - 100 kills with explosives while using perk - 5000 XP Part 5 - 250 kills with explosives while using perk - 10000 XP Part 6 - 500 kills with explosives while using perk - 10000 XP Commando Pro Challenge Part 1 - 2 knife kills while using perk - 500 XP Part 2 - 5 knife kills while using perk - 1000 XP Part 3 - 10 knife kills while using perk - 2500 XP Part 4 - 20 knife kills while using perk - 5000 XP Part 5 - 50 knife kills while using perk - 10000 XP Part 6 - 100 knife kills while using perk - 10000 XP Steady Aim Pro Challenge Part 1 - 10 hip-fire kills while using perk - 500 XP Part 2 - 20 hip-fire kills while using perk - 1000 XP Part 3 - 40 hip-fire kills while using perk - 2500 XP Part 4 - 80 hip-fire kills while using perk - 5000 XP Part 5 - 200 hip-fire kills while using perk - 10000 XP Part 5 - 500 hip-fire kills while using perk - 10000 XP Ninja Pro Challenge Part 1 - Get 5 close range kills while using perk - 500 XP Part 2 - Get 10 close range kills while using perk - 1000 XP Part 3 - Get 25 close range kills while using perk - 2500 XP Part 4 - Get 50 close range kills while using perk - 5000 XP Part 5 - Get 125 close range kills while using perk - 10000 XP Part 6 - Get 250 close range kills while using perk - 10000 XP Scrambler Pro Challenge Part 1 - Get 5 close range kills while using perk - 500 XP Part 2 - Get 10 close range kills while using perk - 1000 XP Part 3 - Get 25 close range kills while using perk - 2500 XP Part 4 - Get 50 close range kills while using perk - 5000 XP Part 5 - Get 125 close range kills while using perk - 10000 XP Part 6 - Get 250 close range kills while using perk - 10000 XP SitRep Pro Challenge Part 1 - Destroy 15 enemy devices or tactical insertions while using perk - 500 XP Part 2 - Destroy 30 enemy devices or tactical insertions while using perk - 1000 XP Part 3 - Destroy 60 enemy devices or tactical insertions while using perk - 2500 XP Part 4 - Destroy 120 enemy devices or tactical insertions while using perk - 5000 XP Part 5 - Destroy 300 enemy devices or tactical insertions while using perk - 10000 XP Part 6 - Destroy 750 enemy devices or tactical insertions while using perk - 10000 XP Last Stand Pro Challenge Part 1 - Get 2 last stand kills while using perk - 500 XP Part 2 - Get 5 last stand kills while using perk - 1000 XP Part 3 - Get 10 last stand kills while using perk - 2500 XP Part 4 - Get 20 last stand kills while using perk - 5000 XP Part 5 - Get 50 last stand kills while using perk - 10000 XP Part 6 - Get 100 last stand kills while using perk - 10000 XP Killstreak Challenges Exposed Challenge Part 1 - Call in 5 UAV's - 1000 XP Part 2 - Call in 25 UAV's - 2500 XP Part 3 - Call in 50 UAV's - 5000 XP Air Mail Challenge Part 1 - Call in 5 care packages - 1000 XP Part 2 - Call in 25 care packages - 2500 XP Part 3 - Call in 50 care packages - 5000 XP Interference Challenge Part 1 - Call in 5 Counter-UAV's - 1000 XP Part 2 - Call in 25 Counter-UAV's - 2500 XP Part 3 - Call in 50 Counter-UAV's - 5000 XP Sentry Veteran Challenge Part 1 - Call in 5 Sentry Guns - 1000 XP Part 2 - Call in 25 Sentry Guns - 2500 XP Part 3 - Call in 50 Sentry Guns - 5000 XP Air to Ground Challenge Part 1 - Call in 5 Predator Missiles - 1000 XP Part 2 - Call in 25 Predator Missiles - 2500 XP Part 3 - Call in 50 Predator Missiles - 5000 XP Airstrike Veteran Challenge Part 1 - Call in 5 Precision Airstrikes - 1500 XP Part 2 - Call in 25 Precision Airstrikes - 3000 XP Part 3 - Call in 50 Precision Airstrikes - 6000 XP Vertical Takeoff Challenge Part 1 - Call in 5 Harrier Strikes - 1500 XP Part 2 - Call in 25 Harrier Strikes - 3000 XP Part 3 - Call in 50 Harrier Strikes - 6000 XP Attack Helicopter Veteran Challenge Part 1 - Call in 5 Attack Helicopters - 1500 XP Part 2 - Call in 25 Attack Helicopters - 3000 XP Part 3 - Call in 50 Attack Helicopters - 6000 XP Special Delivery Challenge Part 1 - Call in 3 Emergency Airdrops - 1500 XP Part 2 - Call in 10 Attack Helicopters - 3000 XP Part 3 - Call in 25 Attack Helicopters - 6000 XP 21 Ton Giants Challenge Part 1 - Call in 3 Pave Lows - 1500 XP Part 2 - Call in 10 Pave Lows - 3000 XP Part 3 - Call in 25 Pave Lows - 6000 XP Stealth Bomber Veteran Challenge Part 1 - Call in 3 Stealth Bombers - 1500 XP Part 2 - Call in 10 Stealth Bombers - 3000 XP Part 3 - Call in 25 Stealth Bombers - 6000 XP Chopper Gunner Veteran Challenge Part 1 - Call in 3 Chopper Gunners - 2500 XP Part 2 - Call in 10 Chopper Gunners - 5000 XP Part 3 - Call in 25 Chopper Gunners - 10000 XP AC 130 Veteran Challenge Part 1 - Call in 3 AC130's - 2500 XP Part 2 - Call in 10 AC130's - 5000 XP Part 3 - Call in 25 AC130's - 10000 XP Blackout Challenge Part 1 - Call in 2 EMP's - 2500 XP Part 2 - Call in 5 EMP's - 5000 XP Part 3 - Call in 10 EMP's - 10000 XP End Game Challenge Part 1 - Call in 2 Nukes - 5000 XP Part 2 - Call in 5 Nukes - 10000 XP Part 3 - Call in 10 Nukes - 10000 XP Radar Inbound Challenge Part 1 - Call in 50 UAV's or Counter UAV's - 2500 XP Part 2 - Call in 100 UAV's or Counter UAV's - 5000 XP Part 3 - Call in 1000 UAV's or Counter UAV's - 10000 XP Airstrike Inbound Challenge Part 1 - Call in 50 Precision, Stealth, or Harrier Strikes - 2500 XP Part 2 - Call in 100 Precision, Stealth, or Harrier Strikes - 5000 XP Part 3 - Call in 1000 Precision, Stealth, or Harrier Strikes - 10000 XP Helicopter Inbound Challenge Part 1 - Call in 50 Armed Helicopters - 2500 XP Part 2 - Call in 100 Armed Helicopters - 5000 XP Part 3 - Call in 1000 Armed Helicopters - 10000 XP Airdrop Inbound Challenge Part 1 - Call in 50 Airdrop Crates - 2500 XP Part 2 - Call in 100 Airdrop Crates- 5000 XP Part 3 - Call in 1000 Airdrop Crates - 10000 XP Basic Training Challenges Ghillie in the Mist Challenge Part 1 - Get 50 one-shot sniper kills - 1000 XP Part 2 - Get 100 one-shot sniper kills - 2500 XP Part 3 - Get 200 one-shot sniper kills - 5000 XP Crouch Shot Challenge Part 1 - Kill 5 enemies while crouching - 500 XP Part 2 - Kill 15 enemies while crouching - 1000 XP Part 3 - Kill 30 enemies while crouching - 2500 XP Prone Shot Challenge Part 1 - Kill 5 enemies while in prone - 500 XP Part 2 - Kill 15 enemies while in prone - 1000 XP Part 3 - Kill 30 enemies while in prone - 2500 XP Point Guard Challenge Part 1 - Get 5 assist kills - 500 XP Part 2 - Get 15 assist kills - 1000 XP Part 3 - Get 30 assist kills - 2500 XP X-ray Vision Challenge Part 1 - Kill 2 enemies through a surface with bullet penetration ( FMG bullets ? ) - 500 XP Part 2 - Kill 5 enemies through a surface with bullet penetration ( FMG bullets ? ) - 1000 XP Part 3 - Kill 15 enemies through a surface with bullet penetration ( FMG bullets ? ) - 2500 XP Backdraft Challenge Part 1 - Destroy 2 enemy explosives - 500 XP Part 2 - Destroy 5 enemy explosives - 1000 XP Part 3 - Destroy 15 enemy explosives - 2500 XP Goodbye Challenge Fall 30 or more feet to your death - 500 XP Base Jump Challenge Fall 15 feet or more & survive - 750 XP Flyswatter Challenge Shoot down an enemy helicopter - 1000 XP Vandalism Challenge Kill an enemy by destroying a car. - 750 XP Operations Challenges Team Player Challenge Part 1 - Win 5 Team Deathmatch matches - 500 XP Part 2 - Win 15 Team Deathmatch matches - 1000 XP Part 3 - Win 30 Team Deathmatch matches - 2500 XP Free For All Victor Challenge Part 1 - Place 1st , 2nd , or 3rd in FFA matches (3 times) - 500 XP Part 2 - Place 1st , 2nd , or 3rd in FFA matches (5 times) - 1000 XP Part 3 - Place 1st , 2nd , or 3rd in FFA matches (10 times) - 2500 XP SD Victor Challenge Part 1 - Win 5 Search & Destroy matches - 500 XP Part 2 - Win 15 Search & Destroy matches - 1000 XP Part 3 - Win 30 Search & Destroy matches - 2500 XP Hardcore Team Player Part 1 - Win 1 Hardcore Team Deathmatch game - 500 XP Part 2 - Win 5 Hardcore Team Deathmatch game - 1000 XP Part 3 - Win 15 Hardcore Team Deathmatch game - 2500 XP Sabotage Victor Challenge Part 1 - Win 5 Sabotage matches - 500 XP Part 2 - Win 20 Sabotage matches - 1000 XP Part 3 - Win 50 Sabotage matches - 2500 XP Bomb Defender Challenge Part 1 - Kill 3 enemies while their defusing the bomb - 500 XP Part 2 - Kill 10 enemies while their defusing the bomb - 1000 XP Bomb Planter Challenge Part 1 - Kill 3 enemies while their planting a bomb - 500 XP Part 2 - Kill 10 enemies while their planting a bomb - 1000 XP Defuser Challenge Part 1 - Defuse 2 bombs in Sabotage - 500 XP Part 2 - Defuse 10 bombs in Sabotage - 1000 XP Saboteur Challenge Part 1 - Plant 2 bombs - 500 XP Part 2 - Plant 10 bombs - 1000 XP Last Man Standing Challenge Be the last man standing in Search & Destroy - 1000 XP MVP Team Hardcore Challenge Be the best player in a Team Hardcore match - 1000 XP Bomb Down Challenge Kill a bomb carrier in either Sabotage or Search & Destroy mode - 1000 XP MVP Team Deathmatch Challenge Be the best player in a Team Deathmatch game - 1000 XP Intimidation Challenges Omnicide Challenge Kill the entire enemy team within 10 seconds - 5000 XP Wargasm Challenge Get all 3 of your killstreak rewards within 20 seconds - 3500 XP The Bigger They Are Challenge Kill the top player 3 times in a row - 2500 XP The Harder They Fall Challenge Kill the top player 5 times in a row - 5000 XP Crab Meat Challenge Kill 10 enemies with a single killstreak - 7500 XP Ultimate Sacrifice Challenge Nuke the enemy while your team is losing - 10000 XP The Denier Challenge Kill an enemy just before they earn a 10 or higher killstreak reward - 5000 XP Carpet Bomb Challenge Kill 5 enemies with a single airstrike - 5000 XP Red Carpet Challenge Kill 6 enemies with a single Stealth Bomber - 5000 XP Grim Reaper Challenge Kill 5 enemies with a single predator missile - 5000 XP No Secrets Challenge Call in a UAV 3 times in a single match - 2500 XP Sunblock Challenge Counter the enemy's UAV 3 times in a single match - 2500 XP Afterburner Challenge Call in an airstrike 2 times in a single match - 2500 XP Air Superiority Challenge Call in a helicopter 2 times in a single match - 2500 XP MG Master Challenge Get a 5 kill streak while on a mounted machine gun - 2500 XP Slasher Challenge Get a 3 melee kill streak without dying - 3500 XP Precision Challenges Assault Expert Challenge Part 1 - Kill 5 enemies with head shots while using an assault rifle - 2000 XP Part 2 - Kill 25 enemies with head shots while using an assault rifle - 5000 XP Part 3 - Kill 50 enemies with head shots while using an assault rifle - 10000 XP SMG Expert Challenge Part 1 - Kill 5 enemies with head shots while using an SMG - 2000 XP Part 2 - Kill 25 enemies with head shots while using an SMG - 5000 XP Part 3 - Kill 50 enemies with head shots while using an SMG - 10000 XP LMG Expert Challenge Part 1 - Kill 5 enemies with head shots while using an LMG - 2000 XP Part 2 - Kill 25 enemies with head shots while using an LMG - 5000 XP Part 3 - Kill 50 enemies with head shots while using an LMG - 10000 XP The Surgical Challenge Fire an entire assault rifle mag into an enemy without missing - 2000 XP Mach 5 Challenge Fire an entire SMG mag into an enemy without missing - 2000 XP Dictator Challenge Fire an entire LMG mag into an enemy without missing - 2000 XP Perfectionist Challenge Fire an entire Sniper mag into an enemy without missing - 2000 XP Multi-RPG Challenge Part 1 - Kill 2 or more enemies with a single AT4 or RPG (5 times) - 2000 XP Part 2 - Kill 2 or more enemies with a single AT4 or RPG (25 times) - 5000 XP Part 3 - Kill 2 or more enemies with a single AT4 or RPG (50 times) - 10000 XP Claymore Challenge Part 1 - Kill 2 or more enemies with a single Claymore (5 times) - 2000 XP Part 2 - Kill 2 or more enemies with a single Claymore (25 times) - 5000 XP Part 3 - Kill 2 or more enemies with a single Claymore (50 times) - 10000 XP Multi-Frag Challenge Part 1 - Kill 2 or more enemies with a single Frag Grenade (5 times) - 2000 XP Part 2 - Kill 2 or more enemies with a single Frag Grenade (25 times) - 5000 XP Part 3 - Kill 2 or more enemies with a single Frag Grenade (50 times) - 10000 XP C4 Challenge Part 1 - Kill 2 or more enemies with C4 (5 times) - 2000 XP Part 2 - Kill 2 or more enemies with C4 (25 times) - 5000 XP Part 3 - Kill 2 or more enemies with C4 (50 times) - 10000 XP Collateral Damage Challenge Kill 2 or more enemies with a single sniper rifle bullet - 2000 XP Flawless Challenge Play an entire match without dying - 2000 XP Fearless Challenge Kill 10 enemies in a single match without dying - 2000 XP Group Hug Challenge Kill multiple enemies with a Semtex Grenade stuck to one of them - 2000 XP NBK Challenge Get 3 longshot kills in one life - 2000 XP All Pro Challenge 2 headshots with 1 bullet - 2000 XP Airborne Get a 2 kill streak with bullets while in midair - 2000 XP Finishing Move Challenges Droppin Crates Challenge Get a game winning Killcam by dropping a crate on the enemy - 2500 XP Absentee Killer Challenge Get a game winning Killcam with a Sentry Gun - 2500 XP Drone Killer Challenge Get a game winning Killcam with a Predator Missile - 2500 XP Finishing Touch Challenge Get a game winning Killcam with a Precision Airstrike - 2500 XP True Liar Challenge Get a game winning Killcam with a Harrier - 2500 XP OG Challenge Get a game winning Killcam with an Attack Helicopter - 2500 XP Transformer Challenge Get a game winning Killcam with a Pave Low - 2500 XP Techno Killer Challenge Get a game winning Killcam with a Stealth Bomber - 2500 XP Hi Def Challenge Get a game winning Killcam with a Chopper Gunner - 2500 XP Death From Above Challenge Get a game winning Killcam with an AC130 - 2500 XP Unbelievable Challenge Get a game winning Killcam with a Throwing Knife kill - 2500 XP Owned Challenge Get a game winning Killcam with a Riot Shield melee kill - 2500 XP Stickman Challenge Stick a Semtex Grenade to the enemy in a game winning Killcam - 2500 XP Last Resort Challenge Get a game winning Killcam while in either Last Stand or Final Stand - 2500 XP Humiliation Challenges Hot Potato Challenge Part 1 - Kill 5 enemies with thrown back grenades - 3000 XP Part 2 - Kill 10 enemies with thrown back grenades - 5000 XP Car Bomb Challenge Part 1 - Kill 5 enemies by destroying cars - 3000 XP Part 2 - Kill 10 enemies by destroying cars - 5000 XP Backstabber Challenge Stab an enemy in the back with your knife - 3000 XP Slow But Sure Challenge Kill an enemy while being stunned by a stun grenade - 3000 XP Misery Loves Company Challenge Kill yourself & 1 enemy by cooking a grenade without throwing it - 3000 XP Ouch Challenge Kill an enemy with a rifle-mounted grenade launcher without detonation. (direct impact) - 3000 XP Rival Challenge Kill the same enemy 5 times in a single match - 3000 XP Cruelty Challenge Kill an enemy , pick up his weapon , and then kill him again with his own weapon - 3000 XP Think Fast Challenge Finish an enemy off by hitting them with a frag grenade. (direct impact..no explosion) - 3000 XP Think Fast Stun Challenge Finish an enemy off by hitting them with a stun grenade. (direct impact..no explosion) - 3000 XP Think Fast Flash Challenge Finish an enemy off by hitting them with a flashbang. (direct impact..no explosion) - 3000 XP Return to Sender Challenge Kill an enemy by shooting their own explosive. (example : claymore) - 3000 XP Blindfire Challenge Kill an enemy while you are still dazed by a flashbang - 3000 XP Hard Landing Challenge Kill an enemy that is in mid-air - 3000 XP Extreme Cruelty Challenge Kill every member of the enemy team without dying. (atleast 4 enemies) - 3000 XP Tango Down Challenge Kill every member of the enemy team. (atleast 4 enemies) - 3000 XP Counter MVP Challenge Kill the #1 player on the enemy team 10 times in a single match - 3000 XP Elite Challenges Master Chef Part 1 - Kill 5 enemies with cooked grenades - 2500 XP Part 2 - Kill 10 enemies with cooked grenades - 5000 XP Part 3 - Kill 20 enemies with cooked grenades - 10000 XP Counter Claymore Challenge Part 1 - kill 3 enemies by shooting a claymore - 2500 XP Part 2 - kill 10 enemies by shooting a claymore - 5000 XP Part 3 - kill 20 enemies by shooting a claymore - 10000 XP Counter C4 Challenge Part 1 - Kill 3 enemies by shooting C4 - 2500 XP Part 2 - Kill 10 enemies by shooting C4 - 5000 XP Part 3 - Kill 20 enemies by shooting C4 - 10000 XP The Brink Challenge Get a 3 or more kill streak while near death - 4500 XP Fast Swap Challenge Hurt an enemy with primary weapon, Then finish them off with a pistol - 4500 XP Star Player Challenge Play an entire match with a 5:1 K/D Ratio - 4500 XP How the ? Challenge Kill an enemy using bullet penetration to shoot explosive device through the wall - 4500 XP Dominos Challenge Kill an enemy by setting off a chain reaction of explosives - 4500 XP Invincible Challenge Get 5 health regenerations from enemy damage in a row, without dying - 4500 XP Survivalist Challenge Survive for 5 minutes straight without dying - 4500 XP Enemy of the State Challenge Kill 3 enemies while your the only one alive on your team - 4500 XP The Resourceful Challenge Kill an enemy by sticking semtex on a teammate - 4500 XP The Survivor Challenge Get a knife kill when all your ammo is empty - 4500 XP Both Barrels Challenge Kill an enemy with the ranger by firing both barrels at the same time - 4500 XP Payback Challenges Time is Money Challenge Part 1 - Get payback 5 times with Semtex - 3500 XP Part 2 - Get payback 25 times with Semtex - 10000 XP I'm Rich Challenge Part 1 - Get payback 5 times with C4 - 3500 XP Part 2 - Get payback 25 times with C4 - 10000 XP Color of Money Challenge Part 1 - Get payback 5 times with Headshots - 3500 XP Part 2 - Get payback 25 times with Headshots - 10000 XP Robin Hood Challenge Part 1 - Get payback 5 times while in Last Stand - 3500 XP Part 2 - Get payback 25 times while in Last Stand - 10000 XP Bang For Your Buck Challenge Part 1 - Get payback 5 times with frag grenades - 3500 XP Part 2 - Get payback 25 times with frag grenades - 10000 XP Overdraft Challenge Get a payback that sticks to the victim - 3500 XP Identity Thief Challenge Get a payback with the killer's copycat class - 3500 XP ATM Challenge Get a payback with a throwing knife - 3500 XP Money Shot Challenge Get a payback in the game winning killcam - 3500 XP Break for the Bank Challenge Get a payback with a claymore - 3500 XP Riot Shield Challenges Sponge Challenge Part 1 - Absorb 1000 damage with your riot shield - 500 XP Part 2 - Absorb 10000 damage with your riot shield - 1000 XP Part 3 - Absorb 50000 damage with your riot shield - 2500 XP Bullet Proof Challenge Part 1 - Deflect 1000 bullets with your riot shield - 500 XP Part 2 - Deflect 10000 bullets with your riot shield - 1000 XP Part 3 - Deflect 50000 bullets with your riot shield - 2500 XP Unbreakable Challenge Part 1 Deflect 10 explosions with your riot shield - 500 XP Part 2 Deflect 50 explosions with your riot shield - 1000 XP Part 3 Deflect 100 explosions with your riot shield - 2500 XP Shield Veteran Challenge Part 1 - Kill 2 enemies with melee Riot Shield attack - 500 XP Part 2 - Kill 5 enemies with melee Riot Shield attack - 1000 XP Part 3 - Kill 15 enemies with melee Riot Shield attack - 2500 XP Smasher Challenge Get a 3 shield bashing kill-streak without dying - 500 XP Back Smasher Challenge Shield bash an enemy from behind - 500 XP Last edited by Guns_LotsOfGuns; 25-11-2009 at 11:05 AM. |
| Quote |
| | #11 |
| Moderator/Games Reviewer | Spec Ops Alpha Predator Drones, favela gangs, sniper rifles and stealth. These Ops are short and sweet. The Pit Clear all of the enemy targets as fast as possible. Shooting civilians will prevent you from getting 3 stars. Est. Opposition: None Classification: Assault Est. Completion Time: 1:00.00 IW Best Time:0:22.60 Sniper Fi Use sniper rifles, claymores and Predator Drones to hold off waves of enemies. Est. Opposition: Light Classification: Wave Defense Est. Completion Time: 4:00.00 IW Best Time:1:55.50 O Cristo Redentor Hunt down and eliminate the Favela gang. Minimize civilian casualties. Est. Opposition: Light Classification: Elimination Est. Completion Time: 2:30.00 IW Best Time:1:16.20 Evasion Use silenced sniper rifles and cunning to slip past the enemy patrols. Est. Opposition: Light Classification: Stealth Est. Completion Time: 3:00.00 IW Best Time:0:43.65 Suspension Push through the invading forces on the bridge to reach the safe zone. Est. Opposition: Medium Classification: Assault Est. Completion Time: 3:30.00 IW Best Time:0:53.00 Bravo AC-130 gunships, snowmobile races, and Vulcan miniguns with explosive ammo. Something for everyone. Earn 4 stars to unlock. Overwatch Rain death from above using an AC-130 gunship to protect your partner. Est. Opposition: Light Classification: Timed Escort Est. Completion Time: 1:30.00 Two Players Required IW Best Time:0:35.45 Body Count Rack up a large enough body count. Quick kills earn larger bonuses. Est. Opposition: Medium Classification: Elimination Est. Completion Time: 2:30.00 IW Best Time:1:16.20 Bomb Squad Race through the Favela marketplace defusing the explosives before it's too late. Est. Opposition: Medium Classification: Timed Assault Est. Completion Time: 2:30.00 IW Best Time:1:14.20 Race Speed your snowmobile down the mountain, dodging trees, rocks and thousand foot drops. Est. Opposition: Minimal Classification: Driving Est. Completion Time: 1:30.00 IW Best Time:1:05.00 Big Brother Explosive ammunition, Vulcan Minigun, Blackhawk Helicopter. Clear the way. Est. Opposition: Medium Classification: Timed Escort Est. Completion Time: 3:00.00 IW Best Time:1:25.90 Two Players Required Charlie Time trials, explosive breaches, boneyards and enemies in Ghillie Suits. Things are getting a bit tougher. Earn 8 stars to unlock. Hidden Evade enemy patrols and Ghillie Snipers near Chernobyl. Est. Opposition: Medium Classification: Stealth Est. Completion Time: 4:30.00 IW Best Time:1:45.60 Breach & Clear Smash through enemy defenses in the Gulag and escape. Est. Opposition: Heavy Classification: Assault Est. Completion Time: 1:30.00 IW Best Time:0:17.00 Time Trial Launch your snowmobile across the chasm before time runs out. Hit the flag gates for extra time. Est. Opposition: Light Classification: Timed Driving Est. Completion Time: 1:30.00 IW Best Time:1:07.00 Homeland Security Sentry guns, Thermal sights, Rocket Launchers and claymores. Defend yourself from the difficult waves of attackers. Est. Opposition: Heavy Classification: Wave Defense Est. Completion Time: 11:00.00 IW Best Time:7:31.20 Snatch & Grab Battle Shadow Company and Juggernauts in the airplane graveyard. Grab the intel and escape to the extraction point. Est. Opposition: Medium Classification: Assault Est. Completion Time: 3:30.00 IW Best Time:1:22.40 Delta Blizzards, airports, estates and bridges. Five challenging Ops. Earn 20 stars to unlock. Wardriving Laze targets for the Stryker armored vehicle. Battle in the 'burbs house to house, room to room. Est. Opposition: Heavy Classification: Assault & Defend Est. Completion Time: 9:00.00 IW Best Time:3:25.25 Wreckage Use C4, grenade launchers, RPGs, sentry guns, semtex and more to destroy every vehicle on the bridge Est. Opposition: Medium Classification: Vehicle Killspree Est. Completion time: 3:30.00 IW Best Time:1:40.40 Acceptable Losses Sabotage the remote airbase with your silenced weapons and heartbeat sensor. Est. Opposition: Medium Classification: Stealth Est. Completion Time: 7:00.00 IW Best Time:0:48.15 Terminal Pummel your way through enemy riot shield ambushes. Est. Opposition: Heavy Classification: Assault Est. Completion Time: 4:00.00 IW Best Time:0:36.40 Estate Takedown Eliminate Ghillie Snipers, Elite Mercenaries and Juggernauts guarding the estate. Est. Opposition: Medium Classification: Elimination Est. Completion Time: 9:00.00 IW Best Time:2:59.60 Echo An oil rig and a favela full of Juggernauts. These Ops are fast and brutal. Earn 40 stars to unlock. Wetwork Breach and clear two deadly rooms full of enemies and hostages to capture the oil rig. Est. Opposition: Massive Classification: Assault Est. Completion Time: 5:00.00 Slow-mo Breach IW Best Time:3:10.30 High Explosive Kill all ten Juggernauts using only explosives and a knife. You'd be insane to even try this. Est. Opposition: Massive Classification: Elimination Est. Completion Time: 6:00.00 Explosives & Knives Only IW Best Time:2:47.70 Armor Piercing Kill all fifteen Juggernauts on the oil rig. This probably isn't even possible. Est. Opposition: Massive Classification: Elimination Est. Completion Time: 7:00.00IW IW Best Time:4:12.25 Last edited by Guns_LotsOfGuns; 15-12-2009 at 12:16 AM. |
| Quote |
| Thanks from: | kav (21-11-2009) |
| | #12 |
New huge section added for the challenges!, thanks to Mr H shingles for the link |
| Quote |
| | #13 |
New updates added! IW Spec Ops best times (Thanks to Stealth Rodeo!) Weapons Damage Chart (Thanks to shil!) Overhead Map Layout Pics (Thanks to bazzabing!) Last edited by Guns_LotsOfGuns; 14-12-2009 at 2:08 PM. |
| Quote |
| Thanks from: | bearman3784 (14-12-2009), Stealth Rodeo (14-12-2009) |
| | #15 |
| Moderator/Games Reviewer | Someones quick off the mark this morning Just noticed and fixed them all Last edited by Guns_LotsOfGuns; 14-12-2009 at 8:51 AM. |
| Quote |
| | #16 |
| Prominent Member |
found this link which helps breakdown which challenge gives which title/emblem might be of use. Callsigns - The Call of Duty Wiki - Call of Duty: Modern Warfare 2, Call of Duty 4, Call of Duty 2, characters, and more |
| Quote |
| Thanks from: | alan280170 (09-03-2010), Guns_LotsOfGuns (17-12-2009) |
| | #18 |
| Member |
Out of interest, Do you guys stop the gun challenges once everything has bveen unlocked, or do you continue once you have hit the 1000 kills with the gun?
| Quote |
| | #19 |
| Ex Member |
I think I have maxed out the M4 this time round, including the 1000 headshots one, but i still use it as I simply like the gun. I think If I ever get to prestige 10 then I will try to do all the challenges for all the guns. |
| Quote |
| | #24 |
| Member |
Not sure if this is the correct place to ask this Question but I always carry a Stinger and my secondry weapon and the challenge is to take down 60 enemy helicopters. Does the choppers that drop the care packages etc count? Ive managed to get them once or twice but must you must be quick and i just didnt know if i was wasting my time trying to shoot these down?
| Quote |
| Post Reply |
E. & O.E.
LinkBack URL
About LinkBacks
