MW2 Sensitivity
Old 12-11-2009, 10:12 AM   #1
majnu's Avatar
21,060, Level: 35
Points: 21,060, Level: 35 Points: 21,060, Level: 35 Points: 21,060, Level: 35
Activity: 99.4%
Activity: 99.4% Activity: 99.4% Activity: 99.4%
Thanks: Gave 931, Got 784
MW2 Sensitivity
With COD WAW my sensitivity was set at 6-7 now on MW2 I have to set it to almost Insane.
On WAW Insane was just plain rediculous and way too fast, is this some kind of feature on MW2 where they have toned down the sensitivity or is it just me?
Old 12-11-2009, 10:14 AM   #2
kav kav is offline
31,132, Level: 43
Points: 31,132, Level: 43 Points: 31,132, Level: 43 Points: 31,132, Level: 43
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 3,609, Got 4,974
Re: MW2 Sensitivity
I have my sensitivity set to "understanding and empathetic, yet masculine at the same time".
Munkey Boy (12-11-2009)
Old 12-11-2009, 10:15 AM   #3
kav kav is offline
31,132, Level: 43
Activity: 31.8%
Re: MW2 Sensitivity
Seriously, mine's at 7, and it's fine for me so far. I'll probably up it a bit when I get more used to the game.
Old 12-11-2009, 10:22 AM   #4
6,280, Level: 18
Points: 6,280, Level: 18 Points: 6,280, Level: 18 Points: 6,280, Level: 18
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 128, Got 272
Re: MW2 Sensitivity
I just play at the default settings (i pretty much do on all shooters actually).
Prefer slower aiming systems though after getting used to games like killzone 2 this year. Makes you feel like you are aiming a gun rather than just moving a target around the screen.
I personally think the sensitivity should change according to how heavy the gun you are carrying is (if it doesn't already, only had a couple of hours play so far).
Old 12-11-2009, 10:34 AM   #5
1,556, Level: 9
Points: 1,556, Level: 9 Points: 1,556, Level: 9 Points: 1,556, Level: 9
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 6, Got 18
Re: MW2 Sensitivity
I think mine was on 7/8 for MW, i put it on 8 after it being the default (and dying alot!) it was too quick for me so its back down to 7 again!
The games unplayable with the default sensitivity for me!
Old 12-11-2009, 10:37 AM   #6
Illustrious Member
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
Re: MW2 Sensitivity
There's sensitivity settings....
I've played with the default settings on all the FPS games I've played. :god
Old 12-11-2009, 10:44 AM   #7
1,373, Level: 8
Points: 1,373, Level: 8 Points: 1,373, Level: 8 Points: 1,373, Level: 8
Activity: 0.7%
Thanks: Gave 34, Got 13
Re: MW2 Sensitivity
I spent so long playing MW1 with the default settings, when I found you could change it, I didn't like anything other than default.. I find the default on MW2 to be fine aswell.
If anything, i'm doing better on this one that I did on the previous one in terms of where I come in the game.
I never came first on COD4, but have done twice on this one.
Old 12-11-2009, 10:54 AM   #8
27,819, Level: 40
Points: 27,819, Level: 40 Points: 27,819, Level: 40 Points: 27,819, Level: 40
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 282, Got 494
Re: MW2 Sensitivity
Default for me otherwise the the sight is all over the screen like a fly on speed.
Old 12-11-2009, 11:19 AM   #9
5,680, Level: 17
Points: 5,680, Level: 17 Points: 5,680, Level: 17 Points: 5,680, Level: 17
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 320, Got 233
Re: MW2 Sensitivity
ditto
Old 12-11-2009, 11:53 AM   #10
majnu's Avatar
21,060, Level: 35
Activity: 99.4%
Re: MW2 Sensitivity
valid point but if you're carrying a heavy weapon like a browning in waw all it did was make you sprint a shorter distance and slower, it did not affect how fast i could turn and kill someone which is to do with the sensitivity setting. As I never played MW1 too much I am still getting used to the gun category's as they are pretty much the same in MW2.
Old 12-11-2009, 7:45 PM   #11
6,797, Level: 19
Points: 6,797, Level: 19 Points: 6,797, Level: 19 Points: 6,797, Level: 19
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 139, Got 55
Re: MW2 Sensitivity
Mine's set to Medium, though I'd like to lower it a bit. Setting it to 1 sensitivity is just plain silly - it's SO slow! Guess I'll have to get used to Medium.
Old 13-11-2009, 12:49 AM   #12
Conspicuous Member
NewBeetle's Avatar
18,815, Level: 33
Points: 18,815, Level: 33 Points: 18,815, Level: 33 Points: 18,815, Level: 33
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 539, Got 731
Re: MW2 Sensitivity
So am I the only one using Low?
Old 13-11-2009, 1:10 AM   #13
11,883, Level: 26
Points: 11,883, Level: 26 Points: 11,883, Level: 26 Points: 11,883, Level: 26
Activity: 29.4%
Activity: 29.4% Activity: 29.4% Activity: 29.4%
Thanks: Gave 564, Got 331
Re: MW2 Sensitivity
Real men play at 1.
Or 2.
Maybe thats just because I snipe... Then again, never really like online play unless its full of snipers!
Old 13-11-2009, 6:41 AM   #14
Illustrious Member
31,232, Level: 43
Re: MW2 Sensitivity
Originally Posted by Dao Fei Long View Post
Real men play at 1.
Or 2.
Snipers....boo, hiss.
I'm not sure if you were in a game with me the other night (FFA)....I could have sworn it was your gamertag I saw.
Old 13-11-2009, 7:12 AM   #15
Illustrious Member
45,900, Level: 52
Points: 45,900, Level: 52 Points: 45,900, Level: 52 Points: 45,900, Level: 52
Activity: 85.1%
Activity: 85.1% Activity: 85.1% Activity: 85.1%
Thanks: Gave 1,843, Got 3,282
Re: MW2 Sensitivity
I play on high sensitivity
Its fine when im sniping and fine when im clearing a room
Old 13-11-2009, 7:55 AM   #16
7,650, Level: 20
Points: 7,650, Level: 20 Points: 7,650, Level: 20 Points: 7,650, Level: 20
Thanks: Gave 99, Got 76
Re: MW2 Sensitivity
I want my mouse and its on the fly sensitivity *sniff*
