Current level: 37
Was 10th prestige on both cod 4 and 5.
In cod 4 the best wepon was the m16 all round. Might not be your favorite but it was the best. As u see they have moved it up to lvl 40 or something recuired. The famas is the new m16 junoir. My current gun is
Primary wepon: Famas with Heartbeat sensor/FNG and silencer
Secondary: Automatic shotgun forget name. If your going for the nuke like i always do go with a wepon since your going to run out if not get a launcher of some sort.
Perks: Bling pro/ Seight of hand pro
Stopping power pro
Scrambler/stead aim pro
Reason for perks
bling is better than seight of hand, because i get a silencer and a heartbeat on my famas. People say why do u have a silencer in core. Because when u come up behind people you dont want a permenant red dot when your shooting. Dont use hardline in core just unless u really want to get some kill streaks and u are not that good. Scrambler because when u come up behind people they cant see you(from a short distance).
You dont need scavenger because if you have the abillity to kill someone they will most likley drop a wepon of your liking.
My killstreaks are
Pave low(9 kills)/ Should be harrier(7 kills)
AC 130(11 kills)
Nuke(25 kills and ends game)
These are my killstreaks not ones that u should be using. I use these to get the nuke. The AC 130 is better than the helicopter gunner for the fact that it it has 3 wepons. If your going for kills and are an average player go for heat seaking misile(5 kills),harrier(7),AC 130(11). If your an above avergae player go for harrier,pave low,AC 130. I choose the harrier because it stacks with your other kill streaks for example: I get thr harrier call my 2 airstrikes get the harrier, gets a minimum of 4 kills. Ok great now i can use the AC 130. The pave low on the other hand does not stack with kill streaks but gets alot of kills 7+ i would say always.
For hardcore (the mode i prefer) my class is.
Primary wepon: Famas/Barret 50. Cal depending on map
Secondary: Machine pistol/Auto shot/Stinger
Perks:
Bling pro
cold blooded(Must need)
ninja/scrambler/sit rep (pros are best of course)
You need cold blood for hardcore so u can be undetected always, even against thermal,air support and sentry guns.
Attachments: Heartbeat sensor on both, so that even if they have cold blood i can still see them if their close.
Silencer for both famas and 50 cal aswell. No need for FNG since 1 shot kill anyways aswell you want to be hidden always to get lots of kill streaks.
Killstreaks: Harrier, Pave low, AC 130. Cant really get nuke in hardcore because only really possible in team death, which is still really hard since u die fast and respawn time.
Sorry for the long post and spelling errors just wanted to say whats best.
P.S. Got 3 Nukes so far
