How to control the AC 130 !
Old 18-11-2009, 10:31 PM   #1
12,610, Level: 26
Points: 12,610, Level: 26 Points: 12,610, Level: 26 Points: 12,610, Level: 26
Activity: 18.9%
Activity: 18.9% Activity: 18.9% Activity: 18.9%
Thanks: Gave 485, Got 104
Just got my first AC 130 and did not have a clue what to do, took me ages to find the zoom.
Is there a link to what buttons control all the guns.
Dave.
PS Have tried Google.
Old 18-11-2009, 10:34 PM   #2
1,962, Level: 10
Points: 1,962, Level: 10 Points: 1,962, Level: 10 Points: 1,962, Level: 10
Thanks: Gave 26, Got 34
Dave.
There's a zoom!? I've only had it once but thought it was great fun!
Old 18-11-2009, 11:03 PM   #3
xSequentialx's Avatar
8,139, Level: 21
Points: 8,139, Level: 21 Points: 8,139, Level: 21 Points: 8,139, Level: 21
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 110, Got 444
R1 is fire, triangle is change gun (different size rounds) and think square is toggle thermal but not sure and left analog to aim.
You have to lead shots as it takes time to reach the ground. There are 3 rounds large (120 i think), medium (40) and small (25). Each gun has quite a lenghty reload time, you can only fire 1 large round before reloading, 4 medium rounds and not sure how many small. Basically the most effective way is to fire the largest round at groups of people or people near cover and whilst the large round is reloading you press triangle to switch to the medium round and fire 4 shots at a single target. Then press triangle twice to switch to the large round (skipping the small round) which will have finished reloading and repeat the process. so firing order is 1 large round, 4 medium, 1 large, 4 medium etc
Dave H (18-11-2009), rousetafarian (19-11-2009), StormLoaded (19-11-2009)
Old 18-11-2009, 11:13 PM   #4
12,610, Level: 26
Activity: 18.9%
Thanks your a star
Old 19-11-2009, 12:30 AM   #5
3,097, Level: 13
Points: 3,097, Level: 13 Points: 3,097, Level: 13 Points: 3,097, Level: 13
Thanks: Gave 6, Got 34
I never knew there was a zoom either! I've had it a couple of times got a few extra kills out of it, it's best used on open maps but people will still run around like legless chickens so you'll get the kills :D
Old 19-11-2009, 7:20 AM   #6
2,446, Level: 11
Points: 2,446, Level: 11 Points: 2,446, Level: 11 Points: 2,446, Level: 11
Thanks: Gave 79, Got 118
Try the Overwatch Spec. Op. for lots of AC-130 practice.
Old 19-11-2009, 7:36 AM   #7
2,245, Level: 10
Points: 2,245, Level: 10 Points: 2,245, Level: 10 Points: 2,245, Level: 10
Thanks: Gave 22, Got 24
Did you mean that? That was funny.
Old 19-11-2009, 8:06 AM   #8
11,500, Level: 25
Points: 11,500, Level: 25 Points: 11,500, Level: 25 Points: 11,500, Level: 25
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 181, Got 338
AFAIK, there isn't a zoom as such - if you change to the smaller guns then your viewpoint is narrower due to the range/effectiveness of the weapon. I've only had the AC130 in MW2 once but I'm pretty sure it operates exactly the same as the single player mission in COD4.
Old 19-11-2009, 8:56 AM   #9
8,373, Level: 21
Points: 8,373, Level: 21 Points: 8,373, Level: 21 Points: 8,373, Level: 21
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 413, Got 375
Your right mate, thats exactly what happens..
Old 19-11-2009, 9:35 AM   #10
6,497, Level: 19
Points: 6,497, Level: 19 Points: 6,497, Level: 19 Points: 6,497, Level: 19
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 92, Got 53
Yeah Iv'e only had one up till now, but It was the most fun you can have with your trousers on.
