Dirty Rotten Laggers
Old 17-11-2009, 12:36 PM   #1
4,833, Level: 16
Points: 4,833, Level: 16 Points: 4,833, Level: 16 Points: 4,833, Level: 16
Thanks: Gave 88, Got 55
Thus far MW2 is absolutely BRILLIANT and I can't get enough of the online multiplayer. However, over the past two days there has been an awful lot more people blatantly lag switching. I've seen as many laggers here in a couple days than what I came across in World at War in over 12 months.
You know the type, teleporting all over the place, knife to the face before you even see anything, 1on1 only for the lagger to teleport & cap you in the ar**.
Anyone else?
Old 17-11-2009, 12:37 PM   #2
Conspicuous Member
Br0ken's Avatar
34,147, Level: 45
Points: 34,147, Level: 45 Points: 34,147, Level: 45 Points: 34,147, Level: 45
Thanks: Gave 591, Got 1,170
Re: Dirty Rotten Laggers
Can't say I've had that displeasure mate, well not yet anyway.
Is a lag switch a physical device then?
Old 17-11-2009, 12:40 PM   #3
4,833, Level: 16
Yeah, there are even instructionals on YouTube on how to make them. Blummin annoying they are.
Old 17-11-2009, 12:43 PM   #4
8,379, Level: 21
Points: 8,379, Level: 21 Points: 8,379, Level: 21 Points: 8,379, Level: 21
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 413, Got 375
Its some home made device which you add a button onto your controller with masking tape! There's plenty of vids on youtube showing you how to do it and also on eBay where you can buy said switch! Pathetic really!
Old 17-11-2009, 12:45 PM   #5
5,222, Level: 17
Points: 5,222, Level: 17 Points: 5,222, Level: 17 Points: 5,222, Level: 17
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 95, Got 48
How much did yours cost Ben
Old 17-11-2009, 12:46 PM   #6
sannan06's Avatar
2,964, Level: 12
Points: 2,964, Level: 12 Points: 2,964, Level: 12 Points: 2,964, Level: 12
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 46, Got 20
Note to self - must check out the lag switch on youtube, as it will help me rank up quicker.
Old 17-11-2009, 12:47 PM   #7
4,906, Level: 16
Points: 4,906, Level: 16 Points: 4,906, Level: 16 Points: 4,906, Level: 16
Thanks: Gave 213, Got 222
in a game of HQ last night with AVF'ers and everyone had 1 orange bar except the host who had 4 green bars.
He had a slight advantage
But, maybe by coincedence, after I had pointed this out - in my usual, quiet and restrained manner - we all went back up to green bars.
probably not a lag switch and just the servers going fubar
Old 17-11-2009, 12:53 PM   #8
1,633, Level: 9
Points: 1,633, Level: 9 Points: 1,633, Level: 9 Points: 1,633, Level: 9
Thanks: Gave 101, Got 21
someone was just doing this to me an hour or so ago.......he moved like 20 ft in 1 sec to melee me about 3 times.....was going to say something but thought it might just me being rubbish
Old 17-11-2009, 12:55 PM   #9
1,962, Level: 10
Points: 1,962, Level: 10 Points: 1,962, Level: 10 Points: 1,962, Level: 10
Thanks: Gave 26, Got 34
I can't believe the little ****ers would do this, whats the point of playing if you need to cheat in this way? Pretty sure I've experienced this, some chump kept freezing and then stabbing me, even though I'd offloaded enough rounds into him. I put it down to server issues, but I'm not so sure now...
Old 17-11-2009, 12:58 PM   #10
Conspicuous Member
Br0ken's Avatar
34,147, Level: 45
What does it do? Too lazy to Google, sorry
Old 17-11-2009, 12:59 PM   #11
4,833, Level: 16
Here's a demo of what lag switching can do. It's on World at War:-
http://www.youtube.com/watch?v=HIdjy6b2LIw
Old 17-11-2009, 1:09 PM   #12
Conspicuous Member
Br0ken's Avatar
34,147, Level: 45
Youtube is blocked at work lol, dont worry i'll find out later on.
Old 17-11-2009, 1:12 PM   #13
4,833, Level: 16
FYI
Lag switches are normally used by unscrupulous players wanting to cheat at online video games. Lag switches are unrelated to normal network switches. Design of a Lag SwitchThe basic lag switch design is a small Ethernet device where either the orange or green wire of a CAT5 cable has been spliced to a push button or other physical switch. This hardware is connected between the game device (PC or console) and the home network router (or modem if no router exists). Operation of a Lag SwitchWhen the switch is activated, the device is designed to function for a few seconds on a timer, effectively blocking all network traffic between the local game device and the Internet temporarily. Used during gameplay, the device causes the person using a lag switch to appear to opponents as frozen while in fact they are still able to play locally and gain advantages in the game.
Old 17-11-2009, 1:14 PM   #14
8,379, Level: 21
Activity: 5.1%
I made mine myself, but i think i made it wrong as it makes me lag but everyone else seems ok?!
Back to the drawing board i think!
Old 17-11-2009, 1:42 PM   #15
Conspicuous Member
Br0ken's Avatar
34,147, Level: 45
I can't say I understand - if the game temporarily has blocked access to the servers then how can the lagger see where you are? Won't you be "frozen" to them?
Old 17-11-2009, 1:53 PM   #16
4,833, Level: 16
Thats it matey. You simply freeze so that they can have their way with you. similarly, the lagger appears to you as either frozen or teleporting or you simply do not see them. Either way whilst this is happening, they are free to run about as normal.
Old 17-11-2009, 2:23 PM   #17
Conspicuous Member
Br0ken's Avatar
34,147, Level: 45
Ah I see, ok, its a two way thing, that makes sense.
I suppose it'd be something like this then;
lagger sees some one, press the switch, run to the side while the person is shooting at their frozen body, switch off, laggers see them 'live' probably still facing where laggers frozen body was and shoots them. Sounds like tonnes of fun to me, how sad.
Old 17-11-2009, 3:16 PM   #18
3,076, Level: 13
Points: 3,076, Level: 13 Points: 3,076, Level: 13 Points: 3,076, Level: 13
Thanks: Gave 1, Got 7
what sort of pathetic tramp do you have to be to make a game lag so that you can score more points.
words fail me sometimes, there cant be anything more lame in this world surely?
Old 17-11-2009, 3:44 PM   #19
6,409, Level: 19
Points: 6,409, Level: 19 Points: 6,409, Level: 19 Points: 6,409, Level: 19
Thanks: Gave 198, Got 109
I lag abit sometimes. I don't have a switch it just happens sometimes. Not everyone is cheating. I hardwired my ps3 but I still get it
Old 17-11-2009, 4:09 PM   #20
4,833, Level: 16
There's quite a difference between unintentional lag and the utilisation of a lag switch and it is quite obvious when it is the latter.
Old 17-11-2009, 4:17 PM   #21
6,409, Level: 19
It's easy to spot I'm not a cheat coz i'm rubbish
Old 17-11-2009, 9:53 PM   #22
DannyL84's Avatar
7,578, Level: 20
Points: 7,578, Level: 20 Points: 7,578, Level: 20 Points: 7,578, Level: 20
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 284, Got 210
Ive just had the displeasure of meeting a lagger , ****ing cheating tw@
Old 17-11-2009, 9:53 PM   #23
1,633, Level: 9
I would have thought it's more about getting satisfaction from winding people up.
Old 19-11-2009, 10:24 AM   #24
4,581, Level: 16
Points: 4,581, Level: 16 Points: 4,581, Level: 16 Points: 4,581, Level: 16
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 41, Got 17
i have often heard of this but until seeing that vid i never knew quite how it worked and that has ****** me off real bad!!! the amount of times that has happened to me in the past...
Effing ****
now i know what to look for i shall be dishing out the abuse the next this happens to me.
cheers for the link.
Last edited by Hillskill; 19-11-2009 at 10:42 AM. Reason: Circumeventing the swear filter:
