MW2 Create A Class: Discussion Thread
Old 14-11-2009, 1:26 PM   #1
6,409, Level: 19
Points: 6,409, Level: 19 Points: 6,409, Level: 19 Points: 6,409, Level: 19
Thanks: Gave 198, Got 109
Exclamation MW2 Create A Class: Discussion Thread
What's the best weapon for on line play? Whenever I go on I seem to pick crap ones & just get spalterated. Course it could be I'm just crap but what is the gun of choice for you guys.
Old 14-11-2009, 1:28 PM   #2
Nezben's Avatar
3,723, Level: 14
Points: 3,723, Level: 14 Points: 3,723, Level: 14 Points: 3,723, Level: 14
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 76, Got 89
re: Your best Weapon & Perk Combos ?
What are you using?
People prefer different guns and they all have pros and cons.
Im using the Famas at the moment and i really like it.
Old 14-11-2009, 1:31 PM   #3
6,409, Level: 19
Ok I'm gonna try that one, can you get a gun with auto aim?
Old 14-11-2009, 1:33 PM   #4
Nezben's Avatar
3,723, Level: 14
Activity: 7.1%
Nope, the auto aim system turns off in multiplayer....
Old 14-11-2009, 1:35 PM   #5
6,409, Level: 19
Damn it, if the others dont have auto aim that means I'm crap. Oh well I'm just gonna have to spend many hours on here till I'm better.
Old 14-11-2009, 1:38 PM   #6
5,893, Level: 18
Points: 5,893, Level: 18 Points: 5,893, Level: 18 Points: 5,893, Level: 18
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 261, Got 243
Stinger for those pesky Harriers, Helos and AC130's
Old 14-11-2009, 1:43 PM   #7
6,409, Level: 19
I need a matrix gun that slows down time so I can see them coming.
Old 14-11-2009, 1:47 PM   #8
5,843, Level: 18
Points: 5,843, Level: 18 Points: 5,843, Level: 18 Points: 5,843, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 758, Got 436
Thats you're second funny post, stop!
Old 14-11-2009, 1:47 PM   #9
5,893, Level: 18
Activity: 5.7%
Joking aside the Famas is quite good to start off with just try and pull the trigger twice to get 2, 3 shot bursts at your trarget.
Old 14-11-2009, 1:53 PM   #10
6,409, Level: 19
If any one wants to play I'm online now as theholyjebus. I'm easy to spot I'll be the one on the ground bleeding
Old 14-11-2009, 2:12 PM   #11
6,409, Level: 19
Aha I've unlocked some weapons. I'm in the game now boys!
Old 14-11-2009, 3:05 PM   #12
Conspicuous Member
Toon's Avatar
24,657, Level: 38
Points: 24,657, Level: 38 Points: 24,657, Level: 38 Points: 24,657, Level: 38
Activity: 44.3%
Activity: 44.3% Activity: 44.3% Activity: 44.3%
Thanks: Gave 657, Got 885
Your
Sorry, I'm bored.
Old 14-11-2009, 3:25 PM   #13
5,990, Level: 18
Points: 5,990, Level: 18 Points: 5,990, Level: 18 Points: 5,990, Level: 18
Thanks: Gave 18, Got 33
Use the heartbeat sensor
Old 14-11-2009, 7:27 PM   #14
2,503, Level: 11
Points: 2,503, Level: 11 Points: 2,503, Level: 11 Points: 2,503, Level: 11
Thanks: Gave 30, Got 7
i'm currently using the fal, previously used the ump.45 first then the tar-21. trying to get it with acog then thermal scope. having trouble killing guys at a distance with the other two, they seem to always run out of sight before i get to hit them again. hopefully since it is single fire, recoil shouldn't be too bad when scoped in.
on the perks side of things, when using scavenger to pick up claymores, claymores you pick up don't blow up?
Old 14-11-2009, 7:30 PM   #15
Conspicuous Member
Toon's Avatar
24,657, Level: 38
Activity: 44.3%
Used that in one game and hated it! Found myself looking at it all the time which resulted in me dying more!
I'm going through all the weapons to do the challenges for them..
I like all the assault rifles and SMGs that I've unlocked so far. Actually think the P90 is the worst of the lot!
Old 14-11-2009, 7:41 PM   #16
SlinkDaddy's Avatar
7,966, Level: 21
Points: 7,966, Level: 21 Points: 7,966, Level: 21 Points: 7,966, Level: 21
Activity: 21.8%
Activity: 21.8% Activity: 21.8% Activity: 21.8%
Thanks: Gave 227, Got 302
The M4 is fantastic IMO. I use it silenced with scavenger, stopping power and steady aim and find it is a really good combo. Steady aim means I win more than I probably should of close range 50-50s even against SMGs. Scavenger means you never run out of ammo (great if you are killstreak chasing to get a nuke like me) and it also resupplies your equipment slot from any enemy you've killed so you can have several grenades in one life or several claymores etc. Stopping power just helps me cos i'm slower than I should be in 50-50s and also gives me quicker kills from long range before the enemy has chance to get out of sight.
IMO its the best all round weapon. You can kill people from across the map or from 10ft away. It's excellent to aim with through the irons so need for red dot and also there is next to no recoil so you can aim whilst still firing really easily which I feel gives me an edge.
Old 14-11-2009, 9:09 PM   #17
3,695, Level: 14
Points: 3,695, Level: 14 Points: 3,695, Level: 14 Points: 3,695, Level: 14
Thanks: Gave 62, Got 4
I find the AA-12 shotgun as a secondary weapon is incredible.
I was playing some games today with nighthawk and unlocked it, it's got the stopping power of a train, only downside is the short range of it.
Old 14-11-2009, 9:22 PM   #18
Hubba-EX's Avatar
12,280, Level: 26
Points: 12,280, Level: 26 Points: 12,280, Level: 26 Points: 12,280, Level: 26
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 222, Got 225
I too like all the guns, (not used the snipers or LMGs yet though). I am no good with single shot semi-autos like FAL, but it feels better then the M14 or G3 from COD4.
Best thing about the P90 (as with COD4) is huge magazine, been using it with marathon because the mag is huge enough to not need the fast reload as much and the 100 bullets mean the scavenger perk is not that necessary.
I am interested to know how the Famas and M16 compare.
Old 14-11-2009, 9:51 PM   #19
2,983, Level: 12
Points: 2,983, Level: 12 Points: 2,983, Level: 12 Points: 2,983, Level: 12
Thanks: Gave 94, Got 40
I was using the SCAR quite a bit with Holographic sight and Silencer. I've just unlocked the FAL and have now switched to this with red dot sight.
I find this much steadier and more control when firing at a distance. Only problem is when you get someone run out in front of you
.......then you start mashing R1 to try and get the kill
Old 14-11-2009, 9:55 PM   #20
3,097, Level: 13
Points: 3,097, Level: 13 Points: 3,097, Level: 13 Points: 3,097, Level: 13
Thanks: Gave 6, Got 34
The same story when I started using the FAMAS, but then realised what good a secondary gun does .
Old 14-11-2009, 10:51 PM   #21
2,096, Level: 10
Points: 2,096, Level: 10 Points: 2,096, Level: 10 Points: 2,096, Level: 10
Thanks: Gave 36, Got 14
My favourite weapon so far is the SCAR-H, I have found it absolutely brutal at pretty much all but the longest of ranges, using it with the Holographic sight and Stopping Power atm.
Old 15-11-2009, 2:34 AM   #22
3,922, Level: 14
Points: 3,922, Level: 14 Points: 3,922, Level: 14 Points: 3,922, Level: 14
Thanks: Gave 10, Got 25
I agree 100% slinky. Mine is now red tiger,going for the last camo (fall). I've done 210 head shots so far. I also love the M16 and ACR. The acr is a mean beast of a gun with very little recoil
Old 15-11-2009, 8:35 AM   #23
6,050, Level: 18
Points: 6,050, Level: 18 Points: 6,050, Level: 18 Points: 6,050, Level: 18
Thanks: Gave 72, Got 98
I use the M16 with the Holographic Scope.
It's short bursts which some don't like cos you don't win 50/50's but 2 quick blasts from any distance & job done.
Just upgraded the Cold Blooded perk to Pro so I can now think about my Secondary weapon instead of the Stinger I've been using.
Old 15-11-2009, 10:39 AM   #24
5,223, Level: 17
Points: 5,223, Level: 17 Points: 5,223, Level: 17 Points: 5,223, Level: 17
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 1,346, Got 236
Perk Combos - What works for you?
Ok, so I'm 10 hours into MW2 and am really enjoying everything (apart from the Hi-de-Hi campers).
My question is around the massive number of Perk combinations available and which combo works the best for you and why?
I seem to be getting spanked by better players constantly and wonder what Perk combos are more popular than others.....
Debate commence.....
Old 15-11-2009, 10:52 AM   #25
10,265, Level: 24
Points: 10,265, Level: 24 Points: 10,265, Level: 24 Points: 10,265, Level: 24
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 176, Got 148
Re: Perk Combos - What works for you?
If you keep getting spanked, i'd go for the anti-spank perk.
Not really sure if any perks help against better players.
Old 15-11-2009, 10:58 AM   #26
5,223, Level: 17
Activity: 6.4%
This is a very good point....
Old 15-11-2009, 11:15 AM   #27
3,695, Level: 14
I was getting spanked royally until i got to rank 20 or so.
I then switched to bling perk so i could have a sliencer and red dot sight, I use scrambler which makes it hard to be seen on radar and stopping power.
i find the use of a silenced weapon and the scrambler essential. I used to play only hardcore on cod4 but alot of people don't and depend on their uav to tell them what is infront of them.
Old 15-11-2009, 11:24 AM   #28
CFH CFH is offline
CFH's Avatar
7,886, Level: 21
Points: 7,886, Level: 21 Points: 7,886, Level: 21 Points: 7,886, Level: 21
Activity: 13.5%
Activity: 13.5% Activity: 13.5% Activity: 13.5%
Thanks: Gave 297, Got 159
SCAR with Bling Pro - heart beat sensor and silencer
Cold Blooded
Ninja
Ultimate in stealth killing and hunting campers
Just want to replace the SCAR with RPD when have unlocked heart beat sensor for it.
Other wise is use Scavenger Pro, Stopping Power Pro, Commando / Scrambler Pro with different assault rifles / smg's
rousetafarian (15-11-2009)
Old 15-11-2009, 12:10 PM   #29
3,202, Level: 13
Points: 3,202, Level: 13 Points: 3,202, Level: 13 Points: 3,202, Level: 13
Thanks: Gave 19, Got 29
Sleight of Hand Pro/Bling Pro depending on the gun
Stopping Power Pro/Hardline
Steady Aim
Don't see much reason for anything else atm
Old 15-11-2009, 2:51 PM   #30
dts197's Avatar
10,812, Level: 24
Points: 10,812, Level: 24 Points: 10,812, Level: 24 Points: 10,812, Level: 24
Thanks: Gave 561, Got 298
It all depends on how good/bad a player you are as to what perks work the best. It also depends on what gun you are using and which map you are playing.
