newbie questions
Thread Closed
Old 13-11-2009, 2:37 PM   #1
6,819, Level: 19
Points: 6,819, Level: 19 Points: 6,819, Level: 19 Points: 6,819, Level: 19
Thanks: Gave 4, Got 1
newbie questions
1. how can you tell who is hosting (is it me?)
2. how can you tell when the enemy has UAV?
3. Where and when will my care package arrive?
Old 13-11-2009, 2:41 PM   #2
Barry_'s Avatar
7,918, Level: 21
Points: 7,918, Level: 21 Points: 7,918, Level: 21 Points: 7,918, Level: 21
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 543, Got 426
Re: newbie questions
1 - not sure
2 - turn your sound up it tells you "enemy UVA is online"
3 - After 4 kills in a row & once you throw the Red smoke grenade/flare (press right on D pad to select) and will appear where you throw the grenade - so don't lob it into the water like i did
Old 13-11-2009, 2:44 PM   #3
1,146, Level: 7
Points: 1,146, Level: 7 Points: 1,146, Level: 7 Points: 1,146, Level: 7
Thanks: Gave 1, Got 3
1. If your the host, you ALWAYS have 4 bars, if you pay close attention to the leaderboard (press select), other people who have 4 bars will occasionally drop to 3 or 2 bars
The host ALWAYS has 4 bars
2. "Enemy UAV is online"
"The enemy's UAV is up"
"ENEMEEII, U A V"
3. When you get 4 kills without dying, you get a flare which you can access with the right directional button
Throw the flare and the care package will be dropped by helicopter 10 seconds later
Make sure you dont get it dropped on a building
Add me: F4H4D_KH4N
Old 13-11-2009, 2:50 PM   #4
3,798, Level: 14
Points: 3,798, Level: 14 Points: 3,798, Level: 14 Points: 3,798, Level: 14
Thanks: Gave 17, Got 17
I wonder how many Care Packages are now stuck waiting on top of buildings and in the water
Old 13-11-2009, 2:55 PM   #5
6,819, Level: 19
thanks guys, see you online tonight!
also where is the juggernaut perk? i die way to easily!
Old 13-11-2009, 3:12 PM   #6
43,182, Level: 50
Points: 43,182, Level: 50 Points: 43,182, Level: 50 Points: 43,182, Level: 50
Activity: 48.5%
Activity: 48.5% Activity: 48.5% Activity: 48.5%
Thanks: Gave 3,072, Got 3,157
Closing. Please read the sticky at the top of the COD Sub Forum
Thread Closed
