Originally Posted by Joe Fernand The cable ‘may’ be correct if your Source can be set to Output a YPbPr ‘Component’ signal via its HD15 (VGA) port!
Otherwise you will require an active Converter to convert RGHBV (VGA) to YPbPr plus set your Source to a Resolution and Refresh rate (1080p60, 720p60, 1080i60 etc.) the TV supports via its 3RCA ‘Component’ Input!
There are low cost devices which will give you an image – though usually pretty poor quality! A half decent converter will cost 150.00 GBP+ CYP Europe - SY-P291 PC/HD to PC/HD Scaler Converter
A New TV with VGA or Component Input may be a better/more cost effective option!
Joe |
So basically, no then ha ha ha.
It sounds like either way the picture isn't going to be good, so out of all the research I have done I am down to the following options -
- Buy a new tele with more options/ports
- Buy an expensive convertor and risk a poor picture
- Buy a cheap(er) VGA to HDMI convertor and have do with the poor picture
- Pay Sky for multi room as I wanted to hook up my Sky Go upstairs !!
Unless there are any other simpler options that i've missed.
But many thanks for your help.
Lee
