2 V+ boxes help
Old 31-03-2009, 7:53 PM   #1
2,426, Level: 11
Points: 2,426, Level: 11 Points: 2,426, Level: 11 Points: 2,426, Level: 11
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Thanks: Gave 4, Got 2
Smile 2 V+ boxes help
Just like to say the threads on Sky v's VM have some really useful discussion, so thank you. They have helped me decide to get VM.
I need 2 boxes for my house, and although I am not fussed about HD, the PVR facility is very important. If I got 2 V+ boxes, is it possible to transfer information from one box the the other? If I record something downstairs, is it possible to watch it upstairs?
THank you.....
Old 01-04-2009, 9:03 AM   #2
3,880, Level: 14
Points: 3,880, Level: 14 Points: 3,880, Level: 14 Points: 3,880, Level: 14
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 15, Got 94
Re: 2 V+ boxes help
Not with the current implementation of the software in the box although the hardware is capable of this.
Old 01-04-2009, 12:43 PM   #3
2,426, Level: 11
Activity: 0.6%
Wink Re: 2 V+ boxes help
Is it possible to transfer data from the V+ box to say a memory card/stick etc so it can be transfered?
I think the only alternative is to record everything on both V+ boxes in case I want to watch it in bed!!
Old 01-04-2009, 12:59 PM   #4
Ben Ben is offline
Ben's Avatar
6,398, Level: 19
Points: 6,398, Level: 19 Points: 6,398, Level: 19 Points: 6,398, Level: 19
Thanks: Gave 3, Got 265
Re: 2 V+ boxes help
Afraid not
You could run coax from one/both V+ STBs to the alternative location(s) or use an AV sender, though coax is preferable
Old 01-04-2009, 1:41 PM   #5
2,426, Level: 11
Activity: 0.6%
Re: 2 V+ boxes help
Originally Posted by Ben View Post
Afraid not
I'm not a technical person on this I'm afraid but appreciate any help you can give.
I know what a Coax cable is, but how do you attach this from the V+ to an alternate TV. Does the receiving TV need to have a V+ or VM box?
What is an STB?
If I use an AV sender, can you recommend one?
thanks in advance
Old 01-04-2009, 2:04 PM   #6
Ben Ben is offline
Ben's Avatar
6,398, Level: 19
Re: 2 V+ boxes help
From the RF output on the back of the V+ to the RF input on your TV*
Nope, as stated above, the coax just connects directly to the TV.
What is an STB?
Sorry, STB just means Set-Top Box.
See here*
* If you receive 2 x Scientific Atlanta V+ and are planning to connect them to your main TVs using HDMI, there are limitations to the above. If you are using scart to connect instead or receive 2 x Samsung V+ instead (new model), then you will not have this issue
Old 02-04-2009, 9:58 AM   #7
2,426, Level: 11
Activity: 0.6%
Re: 2 V+ boxes help
And just one more question, slightly related, I was told by VM that the install is £99 per box. Is it true that some people are paying half price for install by arguing a certain point (ie new customers / old customers get a discount on install).
I only have VM phone and BB.
thanks
Old 02-04-2009, 10:42 AM   #8
Ben Ben is offline
Ben's Avatar
6,398, Level: 19
Re: 2 V+ boxes help
You shouldn't need to argue, it's up on their website until 12th April. See here & here
