Comcast HD in San Francisco, CA
Old 24-03-2009, 7:44 PM   #1
1,933, Level: 10
Points: 1,933, Level: 10 Points: 1,933, Level: 10 Points: 1,933, Level: 10
Thanks: Gave 4, Got 0
We have one HD channel, TNT-HD, that consistently has video/audio sync problems but all other HD broadcasts are great.
My Onkyo receiver has a Lip Sync feature that I've only had to use in conjunction with movies played on my Samsung blu-ray player but never used for cable broadcast channels.
I'm wondering if it's worth the hassle dealing with Comcast just for this one channel that I'm having issues with. Also, if I use the Lip Sync feature adjustment for this one channel, will it "throw off" the sync on my other channels?
Anyone have or experienced a similar issue? Thanks for your time.
Old 24-03-2009, 11:40 PM   #2
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Re: Comcast HD in San Francisco, CA
Sounds like you're USA based.
These forums are European (and we don't have Comcast).
I would suggest posting in AVS Forum
Chris Muriel, Manchester, UK
Old 24-03-2009, 11:47 PM   #3
1,933, Level: 10
Oops! My bad.
