Tiscali tv a couple of questions
Old 26-07-2008, 11:00 AM   #1
2,300, Level: 11
Points: 2,300, Level: 11 Points: 2,300, Level: 11 Points: 2,300, Level: 11
Hi, newbie here, as i can't get cable or sky im thinking about getting Tiscali tv (already on the tiscali max broadband package) I have freeview through my normal tv arial and receive most of the channels although not all of them-hits or tcm i don't get, so will i still get the channels i receive from arial but the ones i can't get come through the phone line? I currently sub to setanta through freeview but only get setanta 1 so i would like to subscribe through tiscali tv as you get the 3 setanta channels my question here is if i want to chuck setanta do i just remove from my tiscali package or do i have to cancel through setanta? I have heard setanta are murder to try and cancel from! Probably more things i will think of but thanks for any info meantime.
Old 30-07-2008, 9:55 AM   #2
3,487, Level: 13
Points: 3,487, Level: 13 Points: 3,487, Level: 13 Points: 3,487, Level: 13
Thanks: Gave 1, Got 4
Re: Tiscali tv a couple of questions
When you have the Tiscali TV service and you order Setanta through Tiscali, if you then wanted to cancel, you would do this through Tiscali.
