Component & VGA to HMDI
Old 16-11-2009, 7:33 PM   #1
2,019, Level: 10
Points: 2,019, Level: 10 Points: 2,019, Level: 10 Points: 2,019, Level: 10
Can anyone tell me how or what I need to convert Component from my Wii to my HMDI and the 15pin VGA from my laptop to my HMDI.
I only have a HMDI cable to my TV.
Old 18-11-2009, 6:41 PM   #2
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Re: Component & VGA to HMDI
Component (from your Wii) is analogue YPrPb.
HDMI is digital and so you would need a (relatively expensive) Component-to-HDMI converter which would include a video analogue to digital converter.
What other output options are available from your Wii ?
What is the make and model number of your TV ?
Chris Muriel, Boston, MA but normally....
Old 21-11-2009, 7:36 PM   #3
1,320, Level: 8
Points: 1,320, Level: 8 Points: 1,320, Level: 8 Points: 1,320, Level: 8
I have a Wii, it's only video connections are composite (they include a composite to SCART adapter with the console) and component. If you want it's best picture quakity then you need to use the component. A quick google found Component Video YPbPr & SPDIF to HDMI Converter Adapter,YPbPr to HDMI Converter as the cheapest component to HDMI converter.
