Virgin media 2 tv's remote controll help
Old 29-10-2009, 9:26 AM   #1
1,362, Level: 8
Points: 1,362, Level: 8 Points: 1,362, Level: 8 Points: 1,362, Level: 8
I have put a 2 way splitter on my hdmi cable and can now watch TV upstairs in HD.I used to use a AV sender but got fed up with interference and no HD upstairs.
My question is how can I change channel upstairs? I see you can buy remote control extenders but how do these work? where do i plug them into?
Old 29-10-2009, 9:57 AM   #2
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
Re: Virgin media 2 tv's remote controll help
Most are designed for connection via a coax cable used for RF distribution. Some are available that just use a pair of wires or Cat 5 cable. If cabling's an issue there are wireless ones, I used to use a Powermid years ago which I see are still available.
The v+ box does use standard IR, not IRDA like some of the earlier (e.g. Pace) boxes.
regards
Brian
