Universal remote help search
Old 15-10-2009, 10:52 AM   #1
1,638, Level: 9
Points: 1,638, Level: 9 Points: 1,638, Level: 9 Points: 1,638, Level: 9
Not sure if this is the right ssction but here goes
Im looking for a Universal Remote Control that will ork on black dimond, tv,ferguson satillite box eurovox cable box nthell cable box, pioneer gr777 graphic equliser, bush dvd vcr recorder sony cd recorder, pioneer tape deck and a sharwood amp some of this stuff is old and remotes broke..anyone no of a good Universal that will do for all above or am i asking for the inposible
Old 15-10-2009, 10:56 AM   #2
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Points: 43,318, Level: 50 Points: 43,318, Level: 50 Points: 43,318, Level: 50
Activity: 85.5%
Activity: 85.5% Activity: 85.5% Activity: 85.5%
Thanks: Gave 467, Got 1,881
Re: Universal remote help search
I don't know if they'll do all of them, but the database is massive and I'd look at the Logitech Harmony range;
Logitech
Old 15-10-2009, 11:24 AM   #3
1,638, Level: 9
Logitech
I have a look it seems hard to find just one remote to do all some i can replace but very expensive one can only try.
Im a villa fan too by the way Was born and raised in brum.
Old 15-10-2009, 11:37 AM   #4
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
I own the 555 and it's a great piece of kit.
You can find them cheaper if you scout around. I think I paid £50 for it, which is not too bad, imo.
The other thing is their customer support is excellent, so if you get in touch, they'll tell you exactly which ones you will or won't be able to control.
Good man
Old 08-11-2009, 8:09 AM   #5
1,994, Level: 10
Points: 1,994, Level: 10 Points: 1,994, Level: 10 Points: 1,994, Level: 10
Thanks: Gave 1, Got 0
Harmony is the way to go, imho.
Even if you have some kit that is not on their massive database - get a remote that can "learn" from your original remote control. A bit of effort but the rewards are well worth it.
I even got mine to learn the codes for a green-i remote dimmer switch - fantastic.
Shaun
