Satellite Cable - can anyone describe the x-section view
Old 13-08-2009, 8:38 PM   #1
1,598, Level: 9
Points: 1,598, Level: 9 Points: 1,598, Level: 9 Points: 1,598, Level: 9
I recently bought some satellite cable for having a wired cabletv point in my living room. However, when I cut the cable, it looks very different to a cross section of normal co-ax cable. It looks to have a number of cavities surrounding the central wire. I'm confused as to which cable to use now. I've got both but should I stick to this satellite one?
Old 13-08-2009, 11:22 PM   #2
Chris Muriel's Avatar
15,699, Level: 30
Points: 15,699, Level: 30 Points: 15,699, Level: 30 Points: 15,699, Level: 30
Activity: 11.1%
Activity: 11.1% Activity: 11.1% Activity: 11.1%
Thanks: Gave 510, Got 629
Re: Satellite Cable - can anyone describe the x-section view
The honeycomb structure should be fine.
Satellite, Television, FM, DAB Aerial Cable, Plugs, Sockets, Connectors & Leads
Jim's Aerials - Aerials & Coax
I would make sure that you use double screeened coax,
Chris Muriel, Manchester
Old 14-08-2009, 11:46 AM   #3
1,598, Level: 9
Hi Chris,
THanks for the reply. Honeycomb is the phrase I was looking for. I'll check my cable according to the links you referenced and get the electrician to sort this out.
Thanks again.
Rajesh
