picture aligment
Old 01-08-2009, 8:32 PM   #1
1,544, Level: 8
Points: 1,544, Level: 8 Points: 1,544, Level: 8 Points: 1,544, Level: 8
picture aligment
I have a Daewoo CRT old TV and have just moved to my new home and had Virgin installed - mainly for the Internet as I am not a big TV person!
However now I have Virgin TV I feel I should use it over free view. I have a V+ box, the problem is that when there is writting that comes up on a program that is near either edge of the screen it hangs off the edge.
I was hoping that in the V box setup there would be an aligment option and I could just pull in the edges but no such luck!!
So how do I get the picture to correctly fit?
Old 03-08-2009, 8:02 AM   #2
11,437, Level: 25
Points: 11,437, Level: 25 Points: 11,437, Level: 25 Points: 11,437, Level: 25
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 257, Got 219
Re: picture aligment
I'm assuming that your CRT is probably not a widescreen set ?. If that is so you need to go into the settings menu on the V+ and set it to 4:3.
