Originally Posted by JonMace You want an analogue TV card and the mce remote it also comes with the IR wands, its a much better setup than V+ |
Hmmmm you'll end up with mono sound and far from stunning picture quality if you use an analogue TV card as the STB takes the digital input, converts it to analogue and then remodulates it with mono sound onto an analogue UHF channel for the TV card to demodulate and redigitise so that the PC can use it (and convert it all back to analogue for the VGA display). The best you can ever hope for is worse than what you would get using the SCART output in composite mode.
You'd be better off using an analogue to digital video card (ideally RGB) and taking sound and video off the SCART.
Also the remote control issue might be a problem if you have an STB which uses IRDA ( the older Pace boxes).
The fundamental issue is that you can't legally stick a DVB-C card into a PC and use it to watch and/or record Virgin Media which would be the easiest technical option.
