New EPG
Old 10-06-2009, 7:55 AM   #1
3,487, Level: 13
Points: 3,487, Level: 13 Points: 3,487, Level: 13 Points: 3,487, Level: 13
Thanks: Gave 1, Got 4
New EPG
New EPG launched this morning
What do you think?
Old 10-06-2009, 9:29 AM   #2
2,456, Level: 11
Points: 2,456, Level: 11 Points: 2,456, Level: 11 Points: 2,456, Level: 11
Thanks: Gave 0, Got 11
Re: New EPG
What do you think?
Personally I would have liked more OD content and more channels but I do like how catch up tv is now listed and you can now get subtitles - I've only noticed them on the DTT channels. There seems to be no change in speed of channel changes and switching on from standby. And most annoyingly the fan still run on the T+ box when it's on standby!
Old 10-06-2009, 3:08 PM   #3
Darko's Avatar
7,033, Level: 19
Points: 7,033, Level: 19 Points: 7,033, Level: 19 Points: 7,033, Level: 19
Thanks: Gave 212, Got 119
Re: New EPG
looks pretty swish and seems to run a bit faster too..
When do we get hd programming as the epg seems to run hd content??
am I right?
Cheers Darko
Old 10-06-2009, 6:38 PM   #4
1,706, Level: 9
Points: 1,706, Level: 9 Points: 1,706, Level: 9 Points: 1,706, Level: 9
Re: New EPG
I think it's much better, even with scart. Am looking forward to hooking up to my proj via HD cable. Widescreen makes more sense. Anyone able to report on pic quality now on hd ready tvs using hd cables?
Old 10-06-2009, 8:15 PM   #5
Darko's Avatar
7,033, Level: 19
Re: New EPG
the colour looks a bit more balanced but the only thing that is improved is the epg pic quality.
Cheers Darko
Old 11-06-2009, 7:55 AM   #6
3,487, Level: 13
Re: New EPG
More details of an Important update regarding your TV service
And a better Frequently Asked Questions about the EPG
And a pretty picture
Old 11-06-2009, 7:58 AM   #7
3,487, Level: 13
Re: New EPG
am I right?
Cheers Darko
To quote MK_Chris (on DS)
Just clear things up:
1. The STB can now display subtitles on DTT (freeview) channels, where
the program includes subtitles. There are currently no subtitles on
VOD or DSL broadcast channels. (By "DTT channel", I mean a channel
where the current source is DTT, even if it can also be sourced over
DSL).
2. The EPG is now fixed at a 16:9 aspect ratio. If the STB is configured
for a 16:9 TV, it fills the whole screen. If the STB is configured
for a 4:3 TV, then the EPG is permanently letterboxed to preserve the
aspect ratio.
3. The EPG is in HD resolution, so looks significantly better over HDMI
than over SCART.
